Weed Pots
Joe Petecki
>Why do weed pots need inserts as in the article in the turning section on Articles and Reviews.
Weed Pots
Joe Petecki
Re: Weed Pots
adrien
>with inserts you can put live flowers in water in 'em.
Otherwise, dried ones do quite well in weed post without inserts.
Re: Weed Pots
adrien
>I forgot--if you send your beloved flowers, they often come with a littleplastic tube of water on the bottom of the stem. They can be used as inserts for weed pots
Re: Weed Pots
Bill Hale / The Wood Spinner
>HEY DO NOT CONSIDER THE LITTLE VIAL ON THE END OF A FLOWER AS WATER. We own a flower shop and those little ends dry up in less than a day. If you want live flowers use the test tube insert and make someone happy.
Good turning and be safe
Bill
Re: Weed Pots
Jennifer@Indy.USA
>Joe,
I haven't read the other responses...but in my opinion, a weed pot is for just that. A weed, or dried flower, which obviously doesn't need water. I just drill a hole for the stems to stand in. If you want a fresh flower in it, then yes, you would want in insert.
Jennifer
Re: Weed Pots
Joe Petecki
>I understand now, thanks for your help. A weed pot may be a very near future project.
Re: Weed Pots
Floyd Knapp
>I make refrigerator weedpots for gifts. Make them small and sand a flat on the back near the top. Drill hole for rare earth magnet and glue in. You can also glue on a suction cup so it can be used on a window or mirror.
Re: Weed Pots -- somewhat OT
Dinyar Chavda
>I think that the term "weed pot" has a very strong pejorative term, particularly among turners---it brings to mind the process by which it is created, i.e., it is not hollowed out, but is just drilled into, and one is obviously limited in terms of what one can use it for.
However, there are weed pots and there are weed pots (and then there is weed / pot, but we won't get into that!)
As some of you know, my wife does Ikebana (Japanese flower arranging), and she was recently helping an older friend get rid of her containers, and she came across this one. Her friend, knowing about my hobby, gave it to her asa present, to thank her for her help.
Technically, it is a weed pot---it has a hole in the top, and there is a (currently broken---where can I get a replacement as it seems to be an unusual size?) test-tube in it.
But to call it a weed-pot is to call the ceiling of the Cistine Chapel just another redecorating job!
I think that there is more than one criterion to be used in evaluating any art/craft object.
Dinyar
Re: Weed Pots -- Inserts *LINK*
>I posted a tip last summer for an easy substitute for the test tube or floral tube. Someone thought it was useful enough to archive it in the WC Articles.
Ron Sardo in PA
>Parkard Woodworks 1-800-683-8876
Craft Supplies 1-800-551-8876
Both places have glass vials for inserts. Don't forget to check at a local medical supply house also.
William's idea is a great one, but hot melt glue, in time, will deteriorate underwater. Check out a pet supply store for some waterproof silicon that is used for fish tanks.
>Thanks for that tip, Ron, I didn't know that. I'll see if I can get Garrett or one of his helpers to update the tip in A&R.
