Making A Disk Sander
Stuart Johnson
>I have an old 1/2 hp motor that I want to turn into a disk sander. My idea is to turn a 12" disk out of mdf and attach it to the motor shaft.Building a box and table isn't going to be a problem. I have run out of ideas for the actual attahment to the shaft. It is a standard 1/2" if that makes any difference.
So far the only idea I have is to turn hub with a 1/2" hole and then glue / screw the mdf disk to it. I can probably use a set screw to hold it on.
Any other ideas? Or, are disks readily available at reasonable prices?
