thanks again to everyone
jim reasoner
>I am going to use all the suggestions on CA application and also experiment with some epoxy. Also will try another style kit and more embellishment on the slimlines. Russ, your site is a wealth of info with the best instructions I have ever seen. I can get a complete education on turning pens and everything else on this forum. Now I just have to put it all into practice. Thanks again.
Re: thanks again to everyone
Greg
>Jim,
I commented earlier about using CA, because that was your question. However, I have mostly shifted to poly glue instead, mainly because of the fumes, not failures (I've done hundreds and hundreds of pens with CA, without failure at all).
If you put a small rubber band around your blank after using the poly, it'll keep the tube inside the blank.
One other little suggestion too - regardless of what glue you use, if you'll plug one end of your tube with some modeling clay, it is much easier to clean up afterwards.
