Features to build in a custom lathe stand?
Mike Schwing from Md.
>While I'm not trying to make a Ferrari out of a Yugo, the stand for my Delta 1440 HAS to go. It has a lot of drawbacks - flimsy stamped steel, very small footprint surface, lightweight..etc. I realize its not a bowl maker's lathe but I will have to live with it for a while longer.
I've decided to build a stand, after trying to mount big chunks of wet wood one too many times and watching my lathe walk across the room.
The design points I want to keep in mind, and add or modify them based on your input (thanks in advance) are;
Keep it slender enough that I can move my body in and get close to the center line of the ways, yet wide enough to provide a firm solid surface that won't twist.
Make the base/feet wide and stout enough to support the weight and give it stability. I like what Chuck did with his feet posted the other day. Looks remarkably stable.
Keep some "air" between the base and the floor for easy sweep up.
Make room for sandbags.
Some storage for tools, sandpaper, etc.
Any other guidelines/rules to follow? What have you found helpful/less than desirable?
No worries about me making it stout enough. I have a lot of 8/4 oak to work with, and I cut my teeth on "flat woodworking".
Thanks.
