REAL MILK PAINT
Pen tube insertion tools ....
Fred L. - North Carolina
>Chopsticks ... waxed ....
FredL
Re: Pen tube insertion tools ....
Peter Teubel
>Fingers...wrapped in a vinyl glove.
RonZ
>Ah so....While I do have a pen insertion tool [I'm a tool junky] I usually use the corner of another piece of wood.
Jim Rutten
>Broken screwdriver filed down on grinder.
Russ Fairfield
>Common wood pencil.
Make sure the glue is dry before sharpening it again.
GENTLE application of rubber mallet...
BubbaBob
Ray
>I use a nail set.
Re: GENTLE application of rubber mallet...
>Bubba:
With due respect for an expert like you, if you need to use a mallet to make the tube go into the blank, there can be two consequences:
1. There will be areas with little or no glue between the tube and the blank. As the blank gets smaller it could break while turning.
2. Since the hole is too small, any movement or drying of the wood can cause cracks that can show immediately or months later.
The tube should be a loose fit in the blank. It should slide freely in the blank, but not too loose. I much prefer epoxy to glue them.
Best regards,
FredL - Nuts in NC.
Fingers...wiped on pants.
Joe Pack
ME an expert? I've only been...
BubbaBob
>...doin' dis pen thang three weeks. I've only done 75 or so pens so far...hardly an expert...but I'm tryin'.
BubbaBob
RevDoug
>Besides a tube insertion tool, the top of the CA bottle. Tappered and works great. Gets renewed when I start using a new bottle.
Turn 'em round,
RevDoug
