Bowl Critiques Please
Lester Gillett in KC Mo
>I have finily finished a couple of plates and
one bowl that i like. I would like to have some
of you experts comment on how they look. The
first on is a sweetgun and boxelder bowl. The
next one is a walnut and honey locust plate.
The last one is a honey locust with wenge inlay
in the borrom.
Re: Bowl Critiques Please
Keith Tompkins
Keith Tompkins
>HI Lester, A couple of thoughts on your pieces. ON two of the pieces, the center disc is oriented face grain as you would turn a bowl, while the outer rings are staves. The wood will have a tendency to expand and contract in different directions, and cause a glue-joint failure. The same thing as glueing in the panel of a raised-panel door...wood wants to move, if you restrict it.....
Your piece with the box alder base does not flow from the sides to the base; it flattens out. from an asthetic point of view, a smooth, continuous flow is preferrable. You can FEEL a good form with your eyes closed. I think that is something to strive for.
On the piece with the wenge center, I think a band of wenge on the rim would tie the piece together, uniting the rim with the center.
This post is not intended to discourage you, rather to save you from some of the problems I've encountered. Keith
>Thanks keith and i see what you mean on the
boxelder bowl. I though about the plate with
wenge of putting a pice in the rim or may be
in the staves to make it look like a spider
web. But was trying to git it done for Xmas
so the wife could use it. The wife is starting
to help me on desgines and i know the turnings
will git better.
Lester
