Salad anyone, spalted alder bowl. Pics
Dave Smith - Longview, WA
>I turned this bowl over a year ago. It developed a crack along a defect in the wood. I filled the crack with black epoxy. It took a couple of pourings to get it all filled. One thing I learned the hard way is to seal the end grain before applying black epoxy. Normally I fill cracks before the finish turning. In this case the alder sucked up the black epoxy through the end grain and it didn�t all turn away. It kinda looks like blue stain in one area on the inside. I think we will keep this bowl. It is the largest bowl I have turned on my Jet 1236.
This piece of alder just started to spalt. There are several nice black line circles. I like the mottled color of alder in this stage. Usually I get spalted alder when it is just short of being good top soil. Those pieces don�t turn very good.
Bowl is 11" wide and 6 1/4" high. The crack is not very wide but it is 7" long.
The side starts 1/4" at the rim and increases to �" at the bottom.
Finish is Woodcraft polyurethane oil. I let the first coat dry about a week. The alder absorbs a lot of finish and I wanted the oil to cure before saturating it again.
Kind of an ugly shape but it will hold alota salad.
Thank you for looking.
Dave Smith
Eating my greens in style in Longview, WA.
Re: Salad anyone, spalted alder bowl. Pics
Terry Quiram
>Hi Dave
Great looking bowl. How many coats of poly oil did you apply? Is the poly a satin finish or did you steel wool it to reduce the shine?
Hope to get some Sassafras ready for you this weekend. Not enough hours in the day!
Terry
Great figure; great shape
David Chung
>and the curve is very efficient and economical.
The proportions are very appealing. I've never turned alder. Is the grain on your piece characteristic of alder?
Just hand buffed for satin look.
>Hi Terry,
There is one coat for the penetrating oil. Woodcraft polyurethane oil has a very stinky solvent but it is non toxic after curing. I applied the finish and reapplied it 30 minutes later. The end grain soaked up a lot of finish. Then I wiped the surface dry and buffed it with a dry towel. The buffing gives a smooth satin look and feel.
Don't worry about the sassafras. Your box of alder is still sitting in my garage. We have had freezing rain the last few days and shipping your box of wood is not an emergency. The box is only lumber. None of the spalted alder.
Dave Smith
Ice is starting to melt in Longview, WA.
Not normal look of alder.
>Hi David,
Alder does not look like that normally. It is a light wood, about 32 lbs per cubic foot, and brittle. So I'm not surprised you have not turned it. But like any wood there are exceptions. Alder has to be power sanded, by me anyway, because of end grain tear out.
Thank you for your kind comments. Which Island do you live on? When we visit we usually go to the Big Island. We didn't plan to go this year but if the weather doesn't change soon I might be heading to Paradise.
Dave Smith
Mike Rubes
>Hi Dave,
Nice bowl. I like the looks of it. It looks like it would have a good heft to it. The "ray" streaks emanating out from the center give it a nice sunburst look.
It looks *much* better than the alder bowl I made last summer to use as a popcorn bowl!
Mike
Once got lost in Longview, WA, far from Apex, NC...
Glenn Hodges
>Wonderful looking bowl, nice lines and color. You might be kin to me with the luck you are having with the crack in that bowl.
Nashville, Georgia
