Red cedar bowl...
Red cedar bowl...
Red cedar bowl...
Marc Phillips
>Today's turning... Red cedar, 11 1/4" wide, 4 1/2" high, just over 1/4" thick... finished with Briwax...
Thanks for looking.. comments and critiques are always welcome... about the bowl or the photos...
Marc
Re: Red cedar bowl...
Mike Schwing from Md.
>Very nice! Bet it smells good, too.
Julie
>very nice, what are you using for your background
Marc Phillips
>Thanks...
It's a dark blue valour I picked up at Walmart a long time ago for some awards display cases I was making ......
I have some seamless paper on order, and I'm hoping that will look nicer...
Marc
Randy Gleckler
>Marc,
That is a really great looking bowl. Very nice.
Randy
Jim Pugh in Ohio
>Marc, very nice bowl. Might I suggest you back your camera up a bit so that the entire bowl is in sharp focus? I notice that the front rim is sharp but that the back of the bowl is 'soft', or going out of focus.
>Marc
Try focusing 1/3 of the way through the bowl if possible. Your camera may have focus lock or manual focus. You also my need to stop the f stop down a little to get more depth of field.
When usingthe digital camera you have the advantage of backing off so the bowl is smaller. This will give you more depth of field also. you can crop the frame on the computer later so the image will now fill the frame. You may have to use a higher resolution on your camera if the image starts to look bad.
This is a technique I've used with film when I could tolerate the loss of sharpness from enlarging.
>Oh shute, I meant to compliment you on the bowl. I like it. I usually make my bowls flare more with a continuous curve from the foot to the lip but that tends to turn it into more of an art bowl. It's not as functional.
Ted Calver
Ted Calver
>I like the shape. Was the wood turned green?
Mike Rubes
>Hi Marc,
Nice bowl. I like the swirling grain patterns and the bark inclusion, they both give a lot of character to the bowl. Just curious, how was the cedar to turn? I've not turned any, but would think it would turn nicely and smell wonderful!
Thanks,
Mike
Time for flat things in Apex, NC....
Michael Marxer, St. Louis, MO
>Hey Marc.
The bowl is nice, and the lighting is good, as well. The backround clashes with the coloring, I think a neutral color, grey or even black, would accent the bowl much better. I also would not have the bowl propped from underneath as you have it.
Nice work, Mike
Barry
>Well, I like the bowl and the photos. Tell me about how you did the photos and what kind of camera you used. Thanks.
Marc Phillips
>Thanks... I'll try that :)
Marc
Marc Phillips
>Thanks John
I have been making all kinds of different shapes, and really haven't figured out any sort of "pattern" yet... but I am getting lots of experience and that's important to me as a beginner... I do know that I like the foot about 1/3 the max diameter, and I seem to lean toward the straight or flared sides as opposed to rounded... but I dont know why!
Thanks again... I appreciate the help...
Marc
Marc Phillips
>I have the disadvantage of having a point and shoot Kodak DX3500... no adjustments at all, just click :)
I will try backing off a little and then crop and see if that helps...
Thanks
Marc
Marc Phillips
>It was a very, very dry blank sent to me by a friend in Florida....
Marc
Marc Phillips
>I had no problems at all really ... and this was my first time turning cedar...
I did notice that it was easy for tiny cracks to form if I sanded enough to make it hot, so I did have to re-turn a small section and then be more careful sanding...
Marc
Marc Phillips
>I agree with all your comments... I have a new background ordered, and the prop underneath was a bad idea...
Thanks... I appreciate the input!
Marc
Marc Phillips
>The photo booth is a copy of Mark Kauder's that he posted here... and I am using a Kodak DX3500.
There's 2 recent posts here... one by Mark Kauder entitled Photo booth pic as requested and another by me entitled Photo booth.
Marc
Keith Tompkins
Keith Tompkins
>That's a very nice piece, it flows from top to bottom, your proportions are good.
It's nice to see you enter posts as "Marc" instead of woodmangler. You can be proud of your work! Keith
