twist vs. click top pens
jim reasoner
>I have noticed in all the catalogs that 90% of the pen kits are the twist operation. Why is this? Are the click kind more difficult to make or what? Personally I prefer the click type, its easier to operate with one hand. Although the variety is very limited I would like to order some click pen sets but would like to find out if there is any real differenc in turning before I do.
Also, anyone ever order anything out of the Packard catalog?
Thanks
Re: twist vs. click top pens
Larry G.
>Hi Jim:
I have made a few of the click type of pens. My only objection is that the center band is an integral part of the mechanism and I feel that this restricts the shape to fit into that "mold"
I prefer the "freedom" that using the slimline type of twist pen gives.
This is a matter of taste and there is no right or wrong.
I have ordered some things from Packard and found them to be a high quality source for tools and accessories.
Good Luck
Larry
Hand Turned Pens at http://pws.chartermi.net/~lgottlieb2/
RevDoug
>I've turned one click and will not turn another. While the turning was no different than any other pen, the assembly was a PITN. Also, I have only had one or two twist pens that I haven't been able to opperate one handed. One was an antler pen that I got too loose. The other was one that I worked on for nearly an hour and it was still too tight to twist open easily. I tossed it and made another just like it that worked without any trouble. Bad kit I assume. What ever you do, have fun. It is one enjoyable hobby, even the problems that cause us to find imaginative solutions.
Turn 'em round,
RevDoug
Scott Greaves, Blackfoot Idaho
>Hi Jim,
Twist pens are easy to make so that they function reliably. Not so with click pens. To make a click pen you must be very meticulous with every aspect of the pen-making process. Make sure your measurements are correct. Even then there will be a few stinkers.
I've had long discussions with Jim at Berea, who admits that their click pen is not everything he would like it to be. But it is a good kit, and with proper care it will make a reliable pen. This is one area that the kit manufacturers are working on, because there is a demand for click pens.
Packard is a great place to order turning supplies from! It is one of the few places that is dedicated to woodturning. Brad Packard is great to deal with, and knows his stuff. But if you are looking at pen kits from them, they are the same thing made by Penn State Industries (PSI). There are only three places that make their own kits, and that is PSI, Berea and Craft Supplies.
Good Luck!
Scott.
Greg
>Jim,
You've already received some excellent advice, and I'd like to add some emphasis to what Scott said - be SURE you don't shorten the brass tubes at all. I understand some kits have a tolerance of less than 1/100th"! I have made many of them and generally don't go all the way to the bras stube when trimming the ends. Some people definitely prefer a click pen, so if you are considering making these for sale (especially), you might want to carry a few of these to avoid lost sales.
Also, if you don't want to be tied to the centerband OD, you can cut your blank in a way so as to cover the centerband.
