REAL MILK PAINT
Vacuum Chuck Seal
Vacuum Chuck Seal
Vacuum Chuck Seal
Stuart Johnson
>What is a good material to use for vacuum chuck seal? I've made one using a pvc coupler and mdf with a piece of rubber router pad glued to the pvc and seem to be getting a fair amount of leakage.
Re: Vacuum Chuck Seal
Brad Adams - Benicia California
>Michael's (large crafty chain store) sells 8x11" sheets of 1/8" thick self adhessive foam sheets. They cost less than a buck each and work great. They also come in a bunch of wild colors. I recommend you get a color that a sharpie pen will show up on. That way you can draw a series of concentic rings on the chuck to make centering easier.
Cheers,
Brad
John
>I use a piece of soft leather on mine. It holds the seal extemely well. Over time, it has been splashed and soaked with walnut oil, and still holds just as well.
Mark Mandell - Gone Round in New Jersey
>Stuart,
I made "drum" chucks out of Sch. 40 PVC in both 4" and 8" sizes. After turning the business ends true, I built up the rims with hot-melt which then is re-turned and shaped on the lathe. Final seals are a section of 1/8" closed-cell foam sheet (quasi-neoprene) that's sold for tool drawer liner. Runs about $15 per roll at HD or Lowes. Adhere it with double-face tape.
Good seal.
Mark Mandell
drop the 2 for mail
Mark Kauder, Phenix City, AL
>Try the fake chamois that you can get at any chain auto parts store. Do not get the "enhanced" stuff that has little holes in it.
It has enough give to form a good seal, but not so much the the work slips off center (main problem with most rubber - mouse pads and the like).
Mark
Fun Foamies
John Trant (aka Boxes-n-Bowls)
>I believe they are called Fun Foamies. I prefer the 2 mm thick sheets (opposed to the 6 mm sheets) on my vacuum chuck. There is less cushion with the 2 mm thick gasket but that means the vessel is more stable while turning. Even if you do not need them for your chuck, I highly recommend keeping both thicknesses in the shop for making gasket/seals for leak-proofing (air or liquid), cushions, push-pads, jigs, etc.
John
Greg
>Stuart,
I just made a vacuum chuck this past weekend, and it only took me about 5 minutes, or less. I already had a piece of hard maple, tapped part of the way through to fit my shaft (1x8.) I screwed it on, trued it up, then cut out my recessed area, leaving a rim of about 1/4" or so. Then I simply used the cheapy neoprene sheets from Walmart (50 cents each), with the self sticking adhesive already on the back. Cut a ring for the front, pressed it on, and went for it. I found that by adding a small ring piece of this same neoprene to the back side of the chuck, it helped improve the vacuum significantly. I am getting about 25 pounds currently. I have a small plywood 'washer' I put on before I screw the chuck on, which forms a nice seal.
One thing I really like about this method is not only is it quick and cheap, but I can make various shapes. I don't know how large of a chuck I can make yet, but for these smaller chucks (3" - 4"), they work great!
>First check for leaks everywhere. MDF doesn't usually leak but seal it with lacquer or some other good finish to stop the leaks there. Plug up the holes with your finger to try to narrow the leaky area. You'll need a gauge on you vacuum system to do this, if you don't already have one.
You can get Neoprene material from Enco. They have it in flat sheets and round tubing. I don't remember there URL but if you'll e-mail me I'll look it up and get back with you. Hobby shops often have thin sheets of closed cell foam which also works good.
Wow What are you using for a rotating air fitting?
Ron Sardo in PA
Re: Wow What are you using for a rotating air fitt
Greg
>Ron,
I bought the vacuum adapter from Oneway, when I bought my Oneway lathe. I felt like that was a crucial element of vacuum chucking, and I'm glad I got it.
Ron Sardo in PA
>Thanks
I misunderstood you - I thought you made the whole assembly.
Shop built rotary Union
Dominic Greco in Richboro, PA
>Ron,
I made my own Rotary Union (as shown below) by following Al Crandal's plans. The only difference is that I used quick disconnect fittings and air hose, versus compression fittings and plastic hose. The entire set up must have cost me under $40.00. At $11.00, I think the hose was the most expensive item.
See ya,
Dominic
