Spindle blank glue ups
Andy in Raleigh
>After my recent gouge break, I had another spooky experience with a small bowl blank. It appears that I was working with some forgiving blanks (or under the watchful eye of a forgiving creator) to make my first few bowls (to use the term loosely). Anyway, I have decided to stick to spindle turning for a while until I get a chance to spend more time with a local bowl turner.
I have a fair amount of 4/4 stock on hand in a few varieties: oak (mostly white, some red), maple (lot of soft, a little hard and a few small pieces of curly), walnut and a little purpleheart. I also have some pear in log form that I could mill square to join.
Anyway, I am planning to do some various combinations of contrasting wood and wanted some input. As an example, let's say I was creating 3" blanks. I could cut 6 boards 1/2" thick, 3" wide and stack them to get that zebra look. I could cut 9 pieces all 1" x 1" and glue them in a 3x3 square (one layer at a time, planing the faces after gluing each layer before joining layers, right?) to get more of a checker board effect.
Any tips on which woods work best or worst together, things to aid in glue up or other suggestions or feedback would be appreciated.
-Andy
Re: Spindle blank glue ups
Bill Howatt
>Andy,
Gluing stock is done all the time and you should follow standard procedures. You want mated surfaces to be very smooth throughout since you don't want to uncover any imperfections as you turn the wood away. This is probably where it is a little trickier than gluing up board edges to make a tabletop since the part of the joint that will ultimately show may be well below the surface that is visible when you do the glueup. For this reason you want it good and flat and smooth.
Wood movement can be a problem so woods with similar movement rates should be used together. You can probably find some relevant movement info on the web if needed.
I have used white, yellow and polyurethane glues.
Bill
