Homebrew Face plates
Fred L. - North Carolina
>A faceplate is easy to make if the proper tap is available to cut the threads. A faceplate can be made from aluminum, which is easy to cut, and even hardwood. The threaded area in a wood faceplate or nut can be reinforced with glue. After a day or so, the tap can be run again to rectify the thread.
Unfortunately the taps that fit lathe threads are not easy to find, and very expensive.
I just ordered a HSS tap 1"-8 from:
http://www.grizzlyoutlet.com
for $4.95.
They also have 3/4"-16, and 3/4"-10 which fits the spindle in some HF lathes, taps at the same price.
They also have a set of Silver & Deming HSS TiN drills with 1/2" shanks. Item H0565. Although the sizes are not listed, from the picture I think they run from 1/2" to 1" and would be useful to drill holes for lathe work.
I hope this will help others facing the same problems.
Regards, Fred
Re: Homebrew Face plates
Peter Teubel
>1x8 taps are easy to find (and cheap). Its the 1 1/4 x 8 that are harder to find AND expensive.
>ENCO has them for about $20. Grizzy Outlet about $5. I thought this was cheaper.
link or model #??
Andy in Raleigh
>I only found a $9.95 item that I think is what you are referring to. Still a good deal, I think, but maybe I am looking at the wrong thing.
-Andy
Re: link or model #??
>Sorry, the $9.95 price is right for the 1-8. It is HSS.
ENCO has both carbon steem, very cheap, and HSS, good price but more expensive.
Fred
Re: 1 1/4 X 8 tap
Doug
>I haven't found a 1 1/4 X 8 tap at any price. If someone knows where to find them please post the info.
Re: 1 1/4 X 8 tap *LINK*
Bruce Williams
>Try victornet.com/
They have a 1 1/4 x 8 #TAST 1-1/4-8 for $43.00.
No affiliation just a satisfied customer.
If the entire link doesn't work, look in the index for "special pitch taps 1 3/16 and larger".
Bruce
http://www.victornet.com/cgi-bin/victor/productlist.html
Re: 1 1/4 X 8 tap
Bill Howatt
>I stumbled across one on ebay. Got it for $15US plus shipping by regular mail.
It was a bottoming or plug tap which would have made it difficult to use in metal without a tapered tap to start the threading. I use it to make MDF faceplates and it works like a charm.
Bill
