What do you use to lub Reeves pully?
Dave Smith - Longview, WA
>I had to disassemble the sliding pully on my Jet 1236 again because it was gummed up and wouldn't slide. The first time it happened I called Jet and they said to spray the shaft with silicone lub. I could just imagine getting silicone on the pullies and belt. I didn't do that. There is a spring loaded ball bearing on the end of the shaft for lubrication but the manual doesn't mention it. The tech people had no idea what lub to use or method of injecting it. This is probably a simple thing but it escapes me.
Dave Smith
Lathe OOC in Longview, WA.
Re: What do you use to lub Reeves pully?
Peter Teubel
I can tell you from direct experience (2 Jet 1236 machines) that the silicone lube works fine. If some lube gets on the belt and pulley...so what? It'll wear off mighty quick. Personally, I use Brake & Contact cleaner on the pulley shaft when it gets sticky. Soak it pretty good, turn on the lathe, and start moving the speed level back and forth. I then spray silicone lube. Has worked for me for the past 2 years.
Dow Dry Film Silicone Lubricant
Dominic Greco in Richboro, PA
>Right off of McMaster Carr's website:
P/N: 1254K12
Dow Corning Dry Film Lubricant 557 Silicone,
11 Ounce Net Weight Aerosol
Quantity Each
1-11 Each $11.93
12 or more 10.79
As addition to using this stuff on my old Jet 1236, I used it to lube my Unisaw's tilt and blade raising mechanisms. Because it is a dry film, it does not attract sawdust. And it lasts for a nice long time.
See ya,
Dominic
Thanks for your input.
>I got it back together tonight. I guess I should get a better maintanence program but I only have so many hours in a day.
Interesting that there is a greese fitting on the shaft but no information for what to use with it. I will try a dry lubricant the next time it acts up.
Dave Smith
Turning again in Longview, WA.
