Micro mesh
Sean Troy
>Hey all, what is the correct way to use Micro mesh? Is it a dry sanding process or just after the piece is finished is it used ? I would like to try it but don't have a clue how to get the best results. Thanks, Sean
Micro mesh
Sean Troy
Re: Micro mesh
Peter Teubel
>I use it exclusivily on pens and other small items. I sand to 600 grit dry, then go thru all the Micro Mesh grits wet....VERY wet. It lasts much longer when used wet.
Re: Micro mesh
Roger Fitzsimonds - Dawsonville GA
>Peter,
What do you keep it wet with .
Thanks
Roger
Re: Micro mesh
John Trant (aka Boxes-n-Bowls)
>Yes, use it wet. You can use water (with a drop of detergent), mineral spirits, or a light oil. It is a great sustitute for pumice and rottenstone or a buffing system when rubbing out a surface. It eliminates the problems with residue or lint getting into natural textures an voids, such as a bark inclusion. Some use it on raw wood but I use it only on finishes and only when I need to use it opposed to the other agents listed above.
John
Re: Micro mesh
Scott Greaves in Blackfoot ID
>Hi Sean,
Micro Mesh is great! I use it exclusively on pens. I sand to 600 grit, then I go all the way through Micro Mesh to 12,000. I use it dry, and with the lathe on high speed. If I do a CA finish I also use it after the finish to shine it up. Keep it moving so it doesn't melt.
Good luck!
Scott.
Re: Micro mesh
Peter Teubel
>Water. Lots of it. I spin pens at 800RPM...slow enough to keep the water from slinging off the piece.
Re: Micro mesh
RonZ
>Isn't thier 1500 equivilent to 600?
Re: Micro mesh
Sean Troy
>Thanks everyone for your help. Sean
Re: Micro mesh
Tony - Memphis
>That's what I have been doing lately on pens. I get a really nice finish doing it that way. Follow up with wax and it looks real nice.
I used to do the raw wood with it, but I found I can't tell the difference. SO now I stop at 600 or 800 maybe then a couple of coats of finish sanding in between maybe, then polish with the micro mesh then wax.
Tony
Re: Micro mesh
>Hi Ron,
Actually, I think that the 600 is just a bit finer than the 1500 MM. I know this will seem odd to some, but there is a difference between "grit" and "mesh" ratings. It doesn't bother me to step back down to the 1500 MM in the middle of my sanding process. When I use the MM to polish up a finish, I start at about 2400 instead.
Scott.
Micro mesh Conversion Chart *LINK*
Russ Fairfield
>This link is to the conversion chart on the manufacturers Website.
Micro-Mesh Grit Size Conversion Chart
