200+ woodworking book reviews
VacuuMaster for Shopsmith
Chuck Ludwigsen
>Bill, I was reading about the Vacuumaster chuck right after telling a friend I could not do vacuum chuck turning because I have a solid spindle lathe.
Both my Shopsmith and my older Buffalo lathe have solid spindle. I have modified the Buffalo to take all the same headstock attachments as my Shopsmith, and it is now my primary lathe.
Do you know if VacuuMaster carries a spindle adapter for 5/8" plain bore? Also, if I start saving for their product, can you post a rough "parts" list of other things I will need to get? Like motor, couplings, guages, etc?
Thanks.
Chuck in Memphis, TN.
Re: VacuuMaster for Shopsmith
A shop-vac powered unit would work
TDaniel
>Vicmarc makes a plate which can be held by your chuck and attaches to a shop-vac. I use this all the time and it holds really well. What it lacks in inches of vacuum it makes up for with volume of air moving. Installation time is about 30 seconds.
TD
Good topic for chatroom
Joel Hunnicutt
>I think vacuum chucking would be a great wed night topic. Your discussion about volume versus vac. pressure would be interesting to bounce around.
Bill Grumbine, Kutztown PA
>Hi Chuck
Look for an email from me. If there is no Shopsmith adapter, it is easy enough to make one.
Bill
Chuck Ludwigsen
>Thanks Bill. I will do that.
And I do think this is a good topic for next Wednesday's chat ;-)
Oh so much to learn. I'm glad every day of life is lesson wanting to be learned.
Kirt
>Hi Bill, I own a Craftsman Variable Speed lathe and it has a solid headstock spindle as well, I would like to know if there is a way or a set-up for vacuum chucking for a solid spindle and if so how ?? Thanks
take care,play safe
"turning to keep warm in the Canadian North"
Kirt
Re: VacuuMaster for Shopsmith *LINK*
>Hi Kirt
The VacuuMaster chuck was developed specifically for solid headstock lathes, although it will work on any lathe. If you go to my personal website (URL below), I have an article on it. Look for an email from me.
Bill
Bill Grumbine's Personal Space
