Questions about an old lathe
Jeremy Osner
>I picked up my Christmas present lathe today, it is an old one -- a Montgomery mini lathe with stand, with a 1/4 hp motor and a 3-jaw Goodall Pratt chuck. I'm ready to start learning to turn! Well, not so fast, I have a couple of questions first...
The 3-jaw chuck seems like it will be useful for finishing projects that are already turned to be round; but I need a regular drive center to start the turning. Thing is, I can't figure out how to take the chuck off! Do I even need to? -- Can I mount a drive center in the hole while the chuck is on there? Eventually I will want to use faceplates too, so I will need to figure out how to get the chuck off eventually -- is there anything I should try?
The motor is connected to the lathe with two drive belts and sets of pulleys. The motor and the axle for the first set of pulleys are mounted on a hinged plate, which keeps tension on the second drive belt. But there is not much tension on the first belt -- I mean it is not loose enough to pull off, but it is not very tight either. How can I make it tighter? If I unbolt the motor I can push it a little farther away from the axle, which would do the trick; but I can't really see how I would be able to keep tension on the belt while I retightened the bolts. Any advice here?
Thanks,
Jeremy
