Making A Handwheel
I want to make a handwheel for my 1969 Delta Rockwell Industrial lathe. The going rate of $39 for a replacement delta seems a bit expensive. I picked up a 8 tpi left hand threaded nut this morning a local industrial supply place. I plan on gluing the nut into the center of a hard maple disk and turning it true. Do any of you see any problems that with this plan? What glue, epoxy, etc. would you recommend?
