Heel shaves for Windsor seats
Joe shelton
Videos by Curtis Buchanan entice me to seek out a heel shave (only one?) but his coverage of it is terse.
Anyone here care to expand on modifying and using one of these?
Re: Heel shaves for Windsor seats
Hi Joe
I have a few of these - 3 or 4 . 5he reason for more than one is that they come with different curvatures, which makes them useful for different curves, nooks and crannies. The blades are often very worn, and full blades are rare. I have had good results turning the blades around on some and grinding a fresh bevel. Others have a wider mouth, but it works.
The handles are removed, as they get in the way.
Below is a photo of a range of spokeshaves I like. A cut down heel shave is at the rear. This is the only photo I could find ...
Jack Guzman from Maine
I build alot of windsor chairs. I have multiple hollowing tools. That is not one of them. Never found a need.
Kevin Adams
The first instructor I built a chair with many years ago had a selection of heel shaves. Most were quite worn as Derek says and the fellow simply buffed the edges on his grinder with a buffing wheel. They worked fine and I was intrigued at the time. However, that was back in the day when there weren’t some really fine travishers available as there are today (and blades so you can make your own). As such, I wouldn’t spend a lot of time looking for them today as you have so many other good choices.
Thanks.
Kevin
john jesseph
Hi Kevin, hope all is well!
Who was the instructor you referred to?
Thanks!
Joe shelton
Jack, what tools do you use to hollow and finish out on the seats?
Joe shelton
Thanks, Derek.
I found one which has a blade with a straight edge, much like those you show. I think I'll file the edge into a concave edge and resharpen. That will allow me to peek thru a little, seeing where I'm about to cut. That capability is what Curtis was most impressed with in the heel shave.
And I'll do that using a shaped block, as you demonstrate. I appreciate your help.
These are the tools I use to hollow chair seats. Jason lonon small bowl adze,Claire Minihan travisher,homemade 12" radius travisher and a Barr tools inshave. I finish with scrapers. I just started using the adze. You don't really need it ,it just makes the process go a little quicker. All the outer concave cuts I make with a drawknife and/or spokeshave.
Joe, just in case it was not obvious enough from the photos, the curved wooden holder is to aid in holding the blades against the wheel at a bench grinder to create a hollow grind.
Kevin Adams
Hi John!
Hope things are well with you, too. We seem to be making it through all this ok. Did you sell your Conover lathe? I wished we were closer!
My first instructor was someone I found off the old Windsor chair resources site, long before there were so many other resources and websites. Back when there were only a small handful of places you could learn chairmaking, with Dunbar of course being the chairmaker’s factory, and then Dave S and Curtis. The guy I went to was Conrad Delia up in Chester, VT. He and his wife ran a lovely B&B where I stayed the week and every morning we walked down to the barn to build a chair. Great memories. That was 20 years ago!
Take care, let’s hope for a good spring and summer ahead
Kevin
Kevin Adams
Hi Jack, that’s almost exactly what I use, although I also recently got one of the travishers from the guy over in England, James Mursell. I quite like it as it can be set fairly coarse and then fine. Claire’s is still in another world.
I like your chairs and appreciate you sharing your work.
Kevin
Conover, Windsorchairresources
john jesseph
Hi again!
I had some interest in the lathe but did not follow up. I’m ambivalent about selling it, so I didn’t provide very good pictures. Life may be bringing some changes, might be dumping all my machines except my bandsaws.
I remember seeing Conrad Delia’s name on windsorchairresources. Sounds like a great experience! So many ways to skin the chair making cat! A lot has come to light in the last 20-25 years, process wise.
I have a hankering to make chairs now!
Found some photos of heel shaves...
As Jack noted, they do the same job as a travisher. Here are two I made (so choose which you want to use) ...
Re: Found some photos of heel shaves...
Kevin Adams
Derek, looks like you cut the handles to make them more useful for your purpose? I like that little scraper there, too. Did you make that yourself? I have one like it that I got from Stu McDonald’s and it’s a handy little tool.
Thanks.
Kevin
Hi Kevin
I made the scraper some years ago from the rear end of a 3/16" thick plane blade. It is modelled after the Stumac scraper. Fantastic scraper!
