Re: WD-40 overspray on milk paint
Mike in Zuni VA
Jack,
This is what is on the Old Fashion Milk Paint's Website:
Porous Surfaces: Milk paint, like all water paints, adheres best to a porous surface, such as bare wood or masonry.
Nonporous Surfaces: Our Extra-Bond additive will help the milk paint adhere to MOST clean, sound nonporous surfaces.
POROUS SURFACES PAINTING PROCEDURES
New wood or other porous surfaces such as masonry.
Note: No primer is necessary – the first coat acts as its own primer on most softwoods and open-grained hardwoods. However, close-grained hardwoods such as maple or birch will require an initial coat of milk paint with Extra-Bond added.
Clean: Wipe down the item with a damp rag to remove any dust and to pre-dampen the surface.
Seal: Then, seal knots, if any (optional) with shellac (apply first coat of milk paint while the shellac is still tacky) OR paint knots with a mixture of prepared milk paint with Extra-Bond added.
First Coat: Paint the entire item with a first coat of milk paint.
Second Coat: After an hour or more, if you wish, you can rub down the first coat lightly with a Scotch- brite pad, fine sandpaper, or non-oiled steel wool[NOTE WEL]. Now, if it looks like it needs it, you can apply a second coat of straight milk paint.
Finished: If you like the look and the rough texture, your masterpiece is finished!!
Optional: After a couple of hours, or overnight, you may wish to rub down to a satin-smooth finish and/or “distress” the finish. You can rub down the surface as in No. 4 above or do any type of distressing at this time. Be sure to try any of these techniques on a test piece to be sure you will like the end result.
Also under Non-Porous Surfaces:
Good finishing practice states that any surface to be painted or repainted must be cleaned and dulled, not shiny. All grime should be removed with a washing soda such as T.S.P. and shiny surfaces should be scuffed up with sandpaper. Surface must be clean, sound and free of oil, grease, dust and dirt.[AGAIN NOTE WELL] By ignoring this practice, the new paint may not adhere well and future coats could peel off when repainted.
Neutralize: On any surfaces that have been chemically stripped of finish, be sure to neutralize any residual chemicals by wiping the surface with a 50/50 vinegar and water solution prior to re-painting.
If it was mine, Sand spots in question to bare wood, use the 50/50 vinegar and water, and repaint the spots. Then do your second coat as planned.
When all else fails read the instructions.
Mike in Zuni A
