the trouble with the white wheel...
David Weaver
...early on is that I was advised that it was friable (it wasn't really in light grinding) and nobody mentioned that I would need to dress it. Mine quickly got glazed and then it burned everything.
After that, I got one of the T shaped diamond dressers and then it was OK, but it wasn't as good as a very coarse gray wheel (Which would glaze easily, but you just don't use it long enough for it to glaze. My cheap gray wheel was either 36 or 46 grit - if you dress wheels for a second each time you grind, it's better than the white one).
The point of this isn't to get into the long settled discussion about various wheels, it's just to point out that if you posted on any forum that you had an 8" high speed grinder with gray wheels and you wanted to grind tools, you'd be advised not to use it (certainly against advising the purchase of any such thing).
My point was really the last one that you make - if you can grind a tool cool with one setup, you can probably do it with all of them. I just have no interest in fine wheels (unless they have CBN, but I can burn the corners of tools on CBN with a heavy hand, too).
The coarser a wheel is, the more room you have for it to continue to run reasonably cool (Without being expensive) than one that's fine. Unless you also have something else you're grinding where you can lean in (if you have mild steel or heavier steel that you need to do significant grinding on, you can get a white wheel to shed particles).
As far as when I burned a couple of tools on a white wheel? I'd say in the first two weeks or a month that I used one. I had a tormek at the time but hated using it (I must've used one, though). Someone mentioned a T dresser on one of the woodworking forums as being unsuitable for anything (they're 10 dollars and easy to use vs. the fairly expensive single point large dressing tools), and I bought one, and still can't figure out why they're unsuitable for dressing wheels.
Once I dressed the white wheel, I dressed the coarse gray wheel on the other side of the grinder and liked it better.
I don't really have a place for woodworking for 3V or any of the steels with a lot of vanadium (except for turning tools, but I have some indifference about those needing to be super long lasting, either - they're quick to sharpen/grind freehand). V11 does great in clean wood for wear resistance, but even at that, for what I typically do, it's a detriment more than a benefit (if you're working by hand, everything before smoothing is the volume of the work and the smoothing is done in a flash). 3v is heat tolerant, though, and as much as LV won't tell folks that V11 can go to higher temperatures, it retains much more hardness if the tip is accidentally browned than would most simpler steels (I believe it's 58 hardness on the tempering chart at 800F).
