Re: pmv11 or a1
David Weaver
O1 - sharpenable on a wider range of stones, often not as hard, or a little overhard where available new
A2 - air hardening steel usually around 61 hardness average. Sharpens well on diamonds and stones with alumina (your term of ceramic stones is more or less this).
V11 - same as A2. Grinds a little bit more slowly.
For practical purposes, V11 obsoletes A2, but not O1. If you're doing purely smoothing in clean wood, etc, V11 is the best there is if you're looking to extend sharpening intervals.
As soon as the work gets a little bit rougher (planing rough wood, wood that has dirt or knots, etc) you'll start to have some disdain for V11s abrasion resistance. A2 is similar without the edge life benefit that V11 gives. It lasts only a little bit longer in ideal conditions, but chips more easily than O1. I think we're going to find that V11 chips more easily than O1 at similar hardness, too, thus the comment about rougher work.
