planing an ash show surface
I am building a desk of ash. It will not be stained. It will be finished with some water based finish that will remain water white (acrylic of some sort). Water on a sanded surface result is swelling and fuzz. Water on a planed surface has much less effect. This desk has many off-set intersections that will be hard to sand between coats, especially the primer coat that will raise grain more, or optimistically less.
I stain most of the woods I build from. I can't control pigment staining on a planed surface. Hence, I have never had need, or desire, for a planed show surface before. My planing has been confined to fitting which is stroke here and there to remove a bit to get a fit. If the result showed it got sanded. My desired goal was to get through a project without the need to sharpen till the end.
Mr. Weaver has done a lot of teaching on the art of planing. I have learned enough from him to attempt planing the show surfaces of the ash parts. I am not attempting these show surface because I believe they will look better than sanded or to achieve a woodworking life style. I am hoping for the practical goal to minimize the time in the finishing step.
What became apparent, as never before planing a few seconds at a time to get a fit with large time gaps between, I could feel the plane getting dull. After what seemed like a small amount of progress, pushing the plane and keeping it in the cut became more effort. But when I did a quick calculation the planing feet add up quick, which leads to dulling that quickly became noticeable in this hard ash. Looking at the blade it was still plenty sharp for any fitting I had ever done, but not for full width shavings off a show surface. The need, that planing enthusiasts advocate, to be able to quickly restore an edge became apparent.
The jury is still out on whether I find planing a show surface of practical benefit in the way I work. It has got to save time on a water based finish. It will not be a benefit for stained cherry and walnut. But I have shown I can do it if need be and thanks to David for getting me to this point. It was quiet and dust-free compared to the 5HP compressor and air driven ROS, but not as fast.
Re: planing an ash show surface
long term benefit...
David Weaver
..you will become very fast at near-finish planing if you choose. By this, I mean removing any of the anomalies that sanded finishers hate (little tiny bits of runout with different finish absorption) and even if you scrape and sand or just sand, those follow-up steps will be very little.
The result will be the option to keep much more crisp lines if you want them. I realize this isn't stylish these days (to have very very crisp lines like the old seaton saw handles had), but the visual effect is stunning (not particularly durable with kids present, but stunning).
George coached me up on this aesthetic very early on, and I've been hooked since where it's possible. dividing curved and flat surfaces ( or anywhere else appropriate) with as crisp of a line as possible. George didn't coach me up on how to get it (he doesn't care about dogmatic method talk - he cares about the visual standard).
Sanding is one of my least favorite things in the world to do. It's completely lacking stimulation and you have to plan to have stock available to sand (and stay on top of it so that you don't get halfway through a project and need to get in the car to go get more, or wait for an order). It's methodical, and progressive if done right and no stray marks or fishhooks left behind. Industrial, dusty, etc, but reliable. In the event that I'm sanding something (like the cabinet in process), if everything can be made to a standard that allows for sanding with a single grit, that's far better.
Needing to take a thin shaving at the very end is the last little bit that really narrows scraping and sanding time. If the surface will be a finished surface without scraping or sanding, much care is needed to make sure the iron has zero defects in it. The same is true of scraping if finishing off of scraping - the burr has to be perfect.
This kind of thing wasn't popular on Knots, though I'm fairly sure now that most of the people claiming to be masters there didn't make much for pay that was worthy of posting. Because.... we didn't see it.
My overall objection to sanding is much deadened after experimenting with several pieces in a/b photos, but the fact that if it's relied on too much, the crispness of the work can end up blah is not deadened.
Your work is crisp and the lines match - nothing to worry about in that case.
It wasn't always the case
Sanding, like any other part of woodworking, benefits from experience. I have on hand at least 1000 sheets of sandpaper ranging from 2000 to 80 grit, so I m never at a loss for sandpaper. (it comes up at flea markets and I snag a pack if it is 10 cents a sheet or less.
People are flocking to spiral head jointers to avoid torn grain. I have stood beside one for long enough that I know how to avoid torn grain with straight knives. All the keen senses that hand planers rely on to get a good edge are useful at a power jointer too to achieve a satisfactory result. The tool is different; the interaction of senses and result is not. That said I keep a hand plane at hand now days. If an edge comes up that needs a shaving or two removed I am likely to fix it in the vise and whisk it away, where as some time ago I would have made a trip across the shop to the jointer. But if I have several panels to assemble from boards I will most surely power joint them. I am frugal about expending effort.
Suggestion......
roger lance
Pre-raise the grain. Use distilled water. Lightly sand the raised fibers with 320/400 grit paper. Apply finish to individual pieces before glue-up.
Re: Suggestion......
Warren in Lancaster, PA
I stopped sanding in 1978, having learned to use the double iron plane a few years earlier. There is no grain to raise if the wood is cut cleanly. I use water stains and can finish as soon as the wood is dry.
