Sweet gum
Sweet gum
Sweet gum
Joe shelton
A neighbor had two large gum trees felled today, and I got a couple small pieces.
I'm not familiar with it. Any merit?
Re: Sweet gum
Re: See attached link
William Duffield
I think you are confused between tupelo (black gum) and sweet gum (sap wood) or red gum (heartwood) of Liquidamber styraciflua.
Except for the interlocked grain, sweet gum works a lot like maple. Back in the early 20th century, they made a lot of furniture with it, after perfecting factory processes for sanded surface prep and heavy staining. I've repaired some pieces. With the exception of the expected failed dowel joinery, the wood is quite suitable for furniture.
Re: Sweet gum
Missed the geographic cue:
Jim Matthews
Huntsville is a long way from Taxachusetts.
Now I've got another domestic species I want to try out!
Re: Sweet gum
Re: Missed the geographic cue:
William Duffield
Yes, but I checked the range maps of both trees. Nyssa sylvatica and Liquidamber styraciflua are both native to both Alabama and Massachusets. I'm therefore unclear what your point is.
Re: Sweet gum
William Duffield
BTW, there are two reasons why bird carvers like tupelo. It is the perfect medium for wood burning feather details. For working water fowl decoy carvers, it floats very well which means you need less weight to keep the bird from rolling over, and is very rot resistant.
Re: Sweet gum
Divided by a common language *LINK*
Jim Matthews
https://www.srs.fs.usda.gov/pubs/misc/ag_654/volume_2/liquidambar/styraciflua.htm
Tupelo is referred to as "Rhode Island Sweet Gum" around here.
https://giphy.com/gifs/ferris-buellers-day-off-its-over-go-home-xT0Gqr2V8DpUGdKgcU
Re: Sweet gum
Re: Divided by a common language
William Duffield
What! No allusion to Oscar the Grouch? :D
I saw that map, which excludes MA, but there are several others that include the state. I'm not a botanist, and I don't play one on TV, so I may be totally wrong. :(
Local, non-scientific names are a problem all over, and even the taxonomists fight at times.
Re: Sweet gum
A few notes.
Warren in Lancaster, PA
I did study botany in college. There are two "gum" trees which are at the edge of their range in Rhode Island and Eastern Massachusetts. One is the Sweet gum, Liquidambar styraciflua, and the other is Black gum, Nyssa sylvatica. Black gum is also called sour gum or black tupelo. There are other tupelos, but Sweet gum is not a tupelo. They are not closely related. Both these trees are planted in Rhode Island and both are growing in the Arnold Arboretum in Cambridge, MA.
For our purposes here, the two woods are similar in appearance, density and hardness. Both have interlocked grain. Both have been used in the furniture industry as secondary woods and stained for primary woods in cabinetry.
Sweet gum has a striking star shaped leaf and corky ridges on the twigs, almost as if diseased. The fruit is a ball just over an inch in diameter with maybe fifty spikes all around like a mace. The balls turn brown in the fall and make it so you don't want bare feet.
The black gum has an oval leaf, about as nondescript as one can imagine, that turns deep red in the fall. The seed of the black gum is a little woody pellet, pea sized but kind of football shaped and easy to miss.
Re: Sweet gum
Brief, interesting experience for me
Joe shelton
Tried splitting out some billets to shave on the horse.
The piece from the tree was 16" diameter and only 21" long. I managed to get a wedge shaped piece off with an arc length of maybe 7" and about 5" on a tangent to that. I used three wedges to try to split it. All three are still buried in the major piece. :\
Went to the horse, and at first thought I had some hope for it, but became almost hopeless because of tear out. When I got as near as I thought I would to a regular sectioned piece, I gave up on shaving to a smaller section.
Tried to rive it. At one point, before I got the froe's blade into the wood, I had a crack 9 1/4" long under the froe. I continued to pound, and finally got the blade fully into the billet, but couldn't make it rive. What little split I got ran out 1 1/2" in about 3".
So I quit. Getting my Froe back out of that entry crack was almost as hard as getting it in to begin with. And when I did, the crack closed up so it was tiny.
If I ever recover my wedges, I've got some really pretty firewood.
Re: Sweet gum
Re: A few notes.
William Duffield
Thanks for the enlightenment. That's interesting, especially the similarities in the wood properties.
I can appreciate the Liquidamber part of the genus name, from the fall leaf color, but I haven't figured out whether styraciflua describes the pointy leaves or the pointy fruit. There is an obvious descriptive relation to styracosaurus.
Re: Sweet gum
Cantankerous
Jim Matthews
My stash was destined for the woodpile, too.
Still- at least the price was right.
Re: Sweet gum
Re: Cantankerous
Joe shelton
Today I managed to recover all three of my wedges. The chunk gave them up grudgingly.
Since it so resistant to axe and trauma, it is now my chopping block.
Re: Sweet gum
Re: Sweet gum
Charlie
Turn of the century four-square homes in Midtown Memphis used red gum/sweet gum for doors, mouldings, and trim profusely. It's beautiful wood -- has a bit of the look of mahogany to my eye. I have one growing in my backyard. They sprout from what we called 'gum balls' as kids -- the spiny seed or whatever they are botanically. I've probably got twenty of them coming up at the base of the tree as I've not done my spring yard clean up just yet, at least not the heavy stuff.
Re: Sweet gum
Trapped wedges are the worst
Jim Matthews
I had similar fouling with local Beech which grows in a spiral.
I ended up cutting gluts to bash the works apart.
Live and learn, die and forget it all anyway.
