I use an earlex wallpaper steamer that I got from Rockler for all my steam bending. I have a high mineral content in my water. It leaves some heavy white scale in any tea pot I have ever used.I assume over a couple years and many steamings this unit is in need of cleaning. Anyone done this? What works?
Jack, we grew up with electric tea kettles and always used white vinegar. 50/50 solution. We also dropped in a little wad of stainless steel wire that would collect the scale. Not sure how or why it worked but it did. I looked it up, here's one...
As much as you use your steamer, it's something to consider...
Ps. We didn't clean it after every use, just every once and a while, sometimes it ended up looking like a little golf ball and we just replaced it...
I might try the vinegar but the stainless wire isn't doable. The earlex steamer is a closed unit. The only access to the inside is through the fill cap.
White or grey scale? I suspect it's a build up of calcium, which may well be the case is your water is described as 'hard' and drawn from a chalky source. Here in the UK we buy lime descaling fluid which gets poured into kettles, coffee machines, steam irons, and the like every once in a while.
I see Home Depot, for one, has a range of similar products that should do the trick; her in the UK we can pick up such products from most local supermarkets. Slainte.
The deposit is calcium carbonate. Any acid will dissolve it. The product mentioned is lactic acid. I don't know any reason that lactic acid would be better than acetic acid except it will stink less and may dissolve iron stain better. There is no reason to dilute white vinegar which is chemically pure acetic acid. Citric acid will work too, probably a bit better in that it may work quicker for some complicated chemical reasons.
I think I'll see what I can accomplish with vinegar. Mainly because I already have some and I would have to go out and purchase some citric acid. thanks
vinegar did the deed. I poured in enough to cover the element which was completely coated in white scale. After soaking an hour alot of the scale had fallen off. I soaked awhile longer then added water and plugged the unit in. That did the trick. Nice clean heating element.
Rockler provides a kit with instructions for building a box like mine. It comes with the steamer. I had built one using 4"pvc pipe but when it gets hot the pipe sags. My box is 60" long and I keep it under a bench so it is not in the way.
I'm not sure what "temper the box" means, but what I do is plug in the steamer and leave the door to the box open. Once steam starts coming out of the door I place the object to be steam bent into the box and close it. That way I get an accurate time for how long the piece was under steam. I also have a thermometer inserted in the top of the box to let me know when the inside of the box reaches top heat.
