need some plane lumber
This used to be the largest of the beech on one of our timber tracts. There is more than 500 bdft in the trunk up to the first limb. It's a monster. I hate beech as they are worthless and shade out a lot of real estate that a good timber tree might occupy. The loss is a mixed blessing. It fell across a logging road and obliterated a key access trail we used for hunting. It will be a job to whack passage through it. It is too far from a road to retrieve for firewood.
Re: need some plane lumber
Beech lumber.....
roger lance
suppose to be good for a workbench also.....just sayin'.
david weaver
I wonder with the tree laying if it's already ruined on the outside of the tree.
I haven't responded partially because we've had company and work is busy, but also because the idea of harvesting wood from a beech tree and getting it dry without spalt or mold, and without cracking or checking, seems to be a tall order.
Like apple, where I couldn't figure out anything about either allowing a lot of spoilage or checking and then just keeping what doesn't spoil, and burn the rest, Or in the case of apple when I found some old quartered as wet as a soup noodle (old full sized tree), I checked it every day, glued any forming checks (it was never subjected to heat) to stop them - it was sealed on the end, these were all side and edge checking, and then once it finally dropped a certain amount, it stopped checking.
Long story short, I have no confidence that I could first tell whether a tree like that is suitable (how straight), and then once figuring that out, that I could get it stickered and dried with good color and no checking.
