Mundane question
Mundane question
Mundane question
Joe shelton
I just got an old Greenlee drawknife. One handle is slightly loose and the ferrule on it spins freely.
I'm concerned that using it this way will further erode the inside of the handle. So, is there a glue that I can drip into the top and solve the problem? If so, what is it?
BTW, I'm not dealing with an heirloom gem here. This is for roughing work.
Re: Mundane question
Jack Guzman from Maine
Can you peen the end to tighten it? If not I imagine epoxy will hold things together.
David Weaver
You can insert some material into the handle with glue (like shims, dots of glue) and probably get the handle tight again without connecting it permanently to the drawknife.
If the handle has any roughness at all, epoxy is probably a permanent fix.
Epoxy, but
I have solved this kind of problem with epoxy....but. In many cases I drizzled it into one hole only to have it run out some undiscovered hole. And tape is not particularly effective for making epoxy dams.
BrianFromMonumentCO
You could use an epoxy that has the consistancy of peanut butter. Acra-gel a product of Brownells is such an epoxy. It is a two part mixture mixed one-to one. It is used by gunsmiths in doing glass bedding of rifle receivers. It doesn't move very much. I use it all the time in fixing handles to files etc. But then again I am a retired gunsmith.
To  make it NOT permanent
BrianFromMonumentCO
If you don't want the acra glass or any other epoxy to bond permanently, coat most of the metal with wax or any other mold release agent. I would try most of the metal except the very point that is in the core of the handle would be coated with a thin layer of wax, the end wouldn't. The handle would fit snug and be held for long time. But would come lose eventually. Grease, oil and some other materials are good release agents.
Thanks, all. Went well
Joe shelton
I decided to try peening. Not knowing how to do it right, I started with a center punch, then tapped until I could tell I'd moved some metal. That snugged the loose handle nicely, and knocked the other one a little loose, so it got peened.
But now two ferrules were loose. I thought that might be a trivial matter, so sharpened it and went to the shave horse, where it had a distinct preference for bevel down work. And the ferrules were a nuisance. So I mixed a little epoxy and very carefully worked it into the ferrule slots.
Appreciate everyone's help, 'specially Jack's injunction to try peening.
