I had fair warning
I had fair warning
I had fair warning
Joe shelton
The instructions for the LVV low angle spokeshave include a notice that the blade might come out during use, and that the way to prevent that is to scuff the mating parts of the blade and the restraining nuts, to get better purchase.
I read those instructions after I got the bleeding stopped, relying on pressure and super glue.
That spokeshave is a good little tool, and I'll continue to use it, after I scuff up those surfaces. And from now on, I'll hold it with all my fingers out on the handles, not riding on the Blade Housing Group!
On the bright side, my newly completed horse works very well. I think of it as a bench horse, because it sits at the end of my saw bench, with quite a bit of room left for sawing.. More importantly, I built it so I can quickly remove all the shaving apparatus if I need the full length of the bench.
Sawing is a lot more fun on a real sawbench than at the workbench.
Re: I had fair warning
Ouch!
John in NM
Sorry to hear it. I've been thinking of getting one of those spokeshave (in kit form).
I have a couple good scars - one from changing blades in a PM100 and doing something stupid. Ain't superglue the stuff? :D Best scar is from a drill press, another nice thing about hand tools is that they cut flesh so much more slowly! :D
Slowly?
Jerry Nicholson
I am not sure about hand tools cutting slowly - I have gouged my hand a few times with a chisel and it seemed pretty fast to me. Not as fast as getting my little finger in a hedge trimmer though - 8 stitches.
Definitely...
John in NM
One of the first things I learned with woodworking is that there is no faster way to mess up a piece of wood than with a router :D Same goes for fingers.
I've had relatively few power tool bites and a couple of near misses that were potentially serious, I'll still take a chisel slice any day even though they too can be serious.
CA Glue
david weaver
I don't cut myself that often in the shop, but so far, I haven't needed more than CA glue for anything. Worst of the lot was grinding a pocket knife blade out of an old hammered file blank - it took a grip (wasn't that sharp yet, and wasn't hardened) on the carborundum stone, flipped over toward my finger and as I was pushing hard to grind it, filleted the center of my middle finger on my left hand (guitar!!! oh no!!)
CA glue and a week, it was OK. A month or so and the feeling was back to normal.
CA glue is also handy in that it may not stop the bleeding, but it will slow it enough to allow you to finish working on whatever you were making.
hand over head, hold whatever got sliced shut, and then glue on top of it after you've folded it shut. (apologies if you already know that).
My mrs. was a wound center physical therapist. She has a cow about that every time I do it (you're going to get an infection!!). Nothing untoward has ever happened and all of the little cuts (including the finger fillet) have healed smoothly and cleanly.
I've gotten infections in stitched wounds, though, and I've had plenty of those - the worst of which was riding an ATV through a window as a kid.
CA Glue wound closure
A lot has been studied on this topic. The full name of the glue is cyanoacrylate. The acrylate part of the name says this stuff is an ester. The rest of the molecule is what enables this stuff to cure to form a glue. The properties of the glue can be modified by diddling with the ester art. In the 60's the army did much research to develop the best wound closing glue by diddling with the ester part.
What we buy for woodworking causes tissue damage in "fresh meat". The Army research developed a product that caused less damage. What surgeons use is not what we are buying. So, if you use woodworking glue to glue a wound together keep it out of the fresh meat.
Water destroys the glue property over time. It is not a permanent wood adhesive.
If it kills finger cells I am sure it kills bacteria so it is probably effective for sterilizing whatever it comes in contact with.
Re: CA Glue wound closure
Joe shelton
No.
Getting it copiously into the "fresh meat" is necessary to staunch the strong flow of blood.
The stuff is not pharmaceutical grade, granted. It is merely the nearest thing found in the realistic woodworker's shop to deal with such minor wounds.
And its lack of efficacy in wood is not germane.
John in NM
I've used the hardware store version in little tubes for years on cuts. In fact, this is the only thing for which I use CA glue. I'm surprised that it destroys cells as it works really well for a quick healing.
I once had a deep, vertical slice in a finger from a new utility knife blade. Once the bleeding slowed I used some CA glue and it was healed in a very short time. Flaps are harder to glue closed.
