Coping saw recommendation
Jerry Gibbs
Looking for a coping saw that I can set adequate tension for removing dovetail waste in 3/4 hardwood. Don’t want to spend $125. Thanks, Jerry
Jerry Gibbs
jewelers saw *LINK*
Jack Guzman from Maine
Any quality coping saw should work. I prefer a jewelers saw for cutting dovetail waste. It uses a narrower blade and is easier to get tight.
jewelers saw
Re: jewelers saw
Jerry Gibbs
I tried a jewelers saw and the blade quickly broke
Coping saw
Warren in Lancaster, PA
I have used the Eclipse saw for thirty some years. Pierced work, scroll work, tracery, dovetails, et cetera. I use it on both pull stroke and push, depending on the work. It costs about $20.
In general a 10$ saw is trash, but for double that you get something worthwhile.
Re: Coping saw
Joe shelton
Doesn't the frame get in the way on wide stock?
Technique and a video
Technique is involved. Most cases of broken blades come down to using too much force. Light pressure and let the blade do the work.
Here I demonstrate using the Knew Concepts fretsaw ..
https://www.youtube.com/watch?v=M6O4rY_0zQs
Incidentally Jerry, while you do not want to spend "$100", if you change your mind, the KC I recommend, is the $99 3" aluminium (red) version. This has a quick tensioner for the blade plus the ability to turn the blade 45 degrees for any length panel.
Re: Coping saw
Does the frame get in the way for wide stock?
If you are talking about dovetails, we usually turn the blade at a slight angle, like 20 degrees, so the frame does not interfere.
If you are talking about pierced work, yes sometimes the frame gets in the way. Sometimes we use a larger saw; sometimes we put the frame in some opening within the piercing in order to saw the stuff that is far from the edge.
Re: Coping saw
Jack Ervin
Olson is my coping saw brand, about same price as eclipse.
I am so glad you're making videos now...
david weaver
..just think about how much easier it is to communicate all of those bits at one time in a video.
It's fun to type in a discussion, but the conversion rate from intended meaning to perceived meaning isn't nearly as good as it is with video.
Re: I am so glad you're making videos now...
Jonathan Elliott
I second that Derek! another happy person.
Miss your videos David but glad they are all there as a resource, I realize all this stuff is very time consuming and don't know how you all have the time to share your experiences like you do so I'm just beyond grateful and hope you all know how appreciated you are! Glad you get enjoyment out of it too.
david weaver
I think it's very time consuming to make good videos.
It doesn't take that much effort to make videos of the type that I made, though, and I wish folks who knew a lot about their area of expertise would be more willing for half an hour a week or so to turn on the camera and show what they're doing.
I understand why people don't want to do it (messing around with it in the middle of a project, getting criticized for not having a BA in video production and teleprompter reading, etc), but the whole woodworking community benefits when people showing work in process are people who do it rather than people selling something other than their work (e.g., product placement with tools, sponsored videos, people trying to maximize patreon and google ads).
I'm kind of out of unique ideas and haven't been making tools too much the last year and a half or so due to playing catch-up with some things my wife wanted to have made (and making several guitars - lots of good video content on that already).
bridger berdel
Can't say I have any particular expertise but here's a video I made planing a large panel:
https://m.youtube.com/watch?v=KleQGHZ7eNI
If anything I'd appreciate technique feedback.
A bit too fast and energetic, Bridger. Have you tried Ritalin?
david weaver
I can't say you should talk as much as I do in my videos - people criticize that a lot, but I'd add narration over that video to describe what you're doing and why. I think you could fill the 1:30 easily explaining the steps and why you're doing what you're doing, how you're holding the work, etc.
Most of the people watching videos like that are probably new and the concept of actually doing a large panel is quickly squashed when they try to do it and blow the back side off planing across the grain because "chris schwarz" showed a specific process.
Time lapse is a great idea on something large like that, though. As time goes on, the tolerance for videos with any dead space in them (as in real time) gets less and less.
Thank you, Warren.
Coincidentally...
Clint Searl
My current project includes six 3 x 1 insets into 1" thick walnut. Having no coping saw at hand, I slowly chiseled out the waste on the first two, but was getting frustrated on the third, that was all cross grain. So it was to HD for their $8.47 coping saw and $2.99 pack of blades. Used it to complete #3-6 in less time than for the first two. It makes me wonder what it is about a $100+ frame that would have made it any better than the one for 1/12th the price.
Re: Coincidentally...
Jim Matthews
Harmonic resonance attuned to the background note of the Universe?
Gotta wonder how many hunnert dolla saws have use the same Olson blade.
