Oul for the outside of a hand plane?
AZ in Colorado Springs
I just cleaned up an old Stanley #4 that I got several years ago. Took it apart and cleaned especially all the threads and put some white grease on them.
I rubbed beeswax on the sole. The sole is ribbed, rather than smooth (don't remember the term for that).
What kind of oil do you use to wipe down the exterior surfaces?
Re: Oul for the outside of a hand plane?
Hank Knight
Don't use oil. Put a little paste wax on the exterior (and the interior) surfaces and buff it. It keeps the rust from undoing all your hard work.
roger lance
AZ.....the term is "corregated"......I use wax or an oil sold by LN.....camiella or jojoba oil.
Gary B
I use a rag in a can oiled, like Paul Sellers uses, with 3 in 1 oil. Super fast and it works well
Thanks. And someday I'll learn to spell "oil" correctly.
Clementine
Where I live "oil" has three syllables and is pronounced "all."
camellia oil
GolfSteve in Calgary
I use camellia oil on my handplanes, scrapers, table-saw top, and lathe bed. It does a good job of reducing surface corrosion. Camellia oil is light, it doesn't smell bad, and it hasn't interfered with any finishes I've applied.
I also live in a region with cool dry climate so rust is not a bit problem.
Re: camellia oil
Rust is not a major worry in Colorado, either. I use paste wax on my machines to allow the stock to glide easily without a strong push. Didn't think of it for handplanes. That's an easy solution though, since I have two cans of Johnson's. I'd read of wiping with an oily rag.
