Three down ..
Three down ..
Three down ..
What happened to number two? Well, that's done too :)
The chair-making tools are now complete. Together with the travisher, a reamer has been completed ...
(I also tweaked the travisher ... I cannot leave anything alone for long)
The reamer is based on the Pete Galbert/Tim Manney design. It features a 6 degree taper (mine ended up at 7 degrees for all the care I took. I doubt this will make any difference).
The blade was made from spring steel ... several years ago Rob Lee passed on a tip about commonly available spring steel (at that time this was for backsaws) in the form of floor scrapers ..
This became a blade 8" long ...
I used the bandsaw an a thin blade to cut the kerf. The blade sits in this nice and snug ...
Wood for the reamer is Hard Maple with a little fiddleback.
The blade can be adjusted via a set screw ...
The pointed end also has a part to play - it is used for sighting angles.
Along the kerf is a gutter to collect shavings ...
The gutter can be seen from the end. It makes the body look lop-sided ...
Once the reamer was completed, a tapered tenon cutter was made to match the reamer. The wood here is a Sheoak ..
All the tools ...
Re: Three down ..
Excellence is a Joy......
Re: Three down ..
Re: Three down ..
Patrick Chase
Very nicely done!
Out of curiosity how much does a floor scraper like that cost?
This may not be relevant to Austrailia, but here in the US you can get blue-hard (Rc50) 1095 reasonably cheaply from McMaster (https://www.mcmaster.com/#blue-spring-steel/=1aq5k1w). If I were going to build my own saw I'd probably go that route.
Re: Three down ..
Re: Floor Scraper Blades
William Duffield
Another source for very similar spring steel is a spackle knife, also known as a joint compound knife or drywall taping tool. Your floor scraper might be easier to use because it is more easily disassembled. In the New World, Marshalltown is a reliable brand.
Re: Three down ..
Re: Australia is a newer world ...
Hank Knight
... at least from a Western Civilization perspective.
Re: Three down ..
Jack Guzman from Maine
Tenon rounder
Nicely done Derek. I never bothered making a tool to form the tenons. What I do is take a 2" block of maple,drill a 5/8" through hole and taper it to my desired size with my reamer. Then I cut the block in half through the center of the hole and use one of these blocks as a tenon sizer on the lathe after my tenon is completely dry.---Jack
Re: Three down ..
Re: Three down ..
William Duffield
https://www.lowes.com/pd/Marshalltown-4-5-in-Blue-Steel-Floor-Scraper/1000210445?cm_mmc=SCE_PLA-_-ToolsAndHardware-_-HardSurfaceTools-_-1000210445:Marshalltown&CAWELAID=&kpid=1000210445&CAGPSPN=pla&store_code=1816&k_clickID=3ccc4891-2402-463c-91fa-36c21a339c3b&gclid=EAIaIQobChMIoqHFxo-S2AIVxrfACh1qTQDJEAQYASABEgLGBfD_BwE
for $20 you'll get enough for 4 reamers.
Re: Three down ..
Re: Tenon rounder
Thanks Jack. I have seen Pete Galbert do that in a video. Perhaps a combination of the two methods makes good practice - get close with the template, and then use the taper sharpener to finish to size.
Re: Three down ..
Re: Three down ..
Patrick Chase
Hmm, it doesn't say what steel it is either there or on the manufacturer's site. "Spring steel" is like "Cr-V" in that it can be a wide range of stuff, though usually at least AISI 1075.
I think I'd pay the extra $10-20 to know that I'm getting properly hardened 1095 in the thickness I want, unless I had no other choice.
Re: Three down ..
Re: Three down ..
Joseph Piotrowski
those are some fine looking tools. excellent work!
Re: Three down ..
Re: Three down ..
William Duffield
Yes, hardened 1095 is a safe bet, and most of us value our time in making a tool much more than a $10 savings. While I have heard rumors of people building backsaws from drywall tools they picked up at the Borg, I have not heard subsequent reports of the durability of the sharpened teeth. While some manufacturers will use high quality steel for these definitely abrasive applications, the home centers know they also have customers whose only purchase criterion is price (and maybe color :) ), and so will also offer things that just look like tools. Even Marshalltown may have suffered quality degradation over the years. I would trust the steel in the masonry tools I got from my dad, who was a plasterer, but I have no long term test results on new tools.
Re: Three down ..
Very Nice!...
david weaver
....and you're making tools while I'm taking pictures of edges with a microscope.
I am jealous, and can't really blame anyone else for it, either.
Re: Three down ..
Drywall tools
Bruce, a MN Galoot
I once picked up a 12” drywall knife with the intention to make a backsaw of some sort. Still haven’t done it.
Unsure of the suitability of the steel, I called the manufacturer and was told that the steel was 1095. Don’t know the hardness, but the type certainly will work.
Re: Three down ..
Re: Drywall tools
Patrick Chase
If it's 1095 and is covered with blue oxides from tempering (a.k.a. "blue spring steel") then it's going to be around Rc50, which is a decent starting point for a saw.
Re: Three down ..
Re: Drywall tools
Bruce, a MN Galoot
They said it’s 1095, and it’s blue!
Re: Three down ..
I did the same once...
John in NM
I was going to use it for the sole of a shop made compass plane.... it sat for 6 months or so while I worked on other stuff, and then I had to do some drywalling :D
Gotta pick up another one of these days! :D
