Router Plane Blade??
Tom Norton
With all this cold and snow it is time to turn to some projects!
Wondering about making a router plane. Found a number of ideas but wonder about making the iron? Saw one idea of using a hex key/wrench.
But am open to any suggestions.
Thanks!
Re: Router Plane Blade??
david weaver
I'd buy O1 stock that is the thickness of the iron width that you want, and in a size large enough that you have the lateral room to cut out the blade. Then cut it out, file it and make it.
Don't forget the clearance on the bottom. Not sure if it's the standard 10 degrees, but you need it for reasonable sharpening.
Should be easy to harden with a single torch and a small oil quench.
Not sure if LV irons fit routers, but they are good quality, and apparently paul sellers' talk of the router plane has driven prices up (I see used cutters on ebay for $30+, which is foolish).
Having mostly hand tools for the kind of work I'm talking about making an iron, i would suspect that it would take me about two hours to make an iron and harden it. My experience leads me to believe that I'd rather have a purchased casted metal router plane with an adjuster than a wooden one.
Wiley Horne--So. Calif.
Hi Tom,
Welcome! If you have a hankering to do some metal grinding, then have at it! Otherwise you wn’t Go wrong with these, say, the 1/4” one for openers. They arrive sharp sharp, and at the right clearance.
http://www.leevalley.com/us/wood/page.aspx?p=67484&cat=1,230,41182,43698,67484
Wiley
Re: Router Plane Blade?? *LINK*
Hi Tom
I recommend building a router plane around the Veritas (Lee Valley) router plane blades. They have a wide selection, and this will enable you to make a plane that is a useful tool, rather than a novel tool that sits on a shelf.
I have also linked to an article of mine below, which includes a plan for building a wooden router plane. I designed and built this as a size below the Large router planes at a time there was nothing similar available. It is a wonderful little router plane ...
Router plane
One other consideration
The LV cutters all have the same shank, independent of the cutter width. This simplifies the blade holding mechanism compared to options where the shank size varies width the cutting width.
Wiley
roger lance
What would really be interesting is to convert a LV router plane blade into a hex wrench.
roger lance
You could just make a simple, functional router plane with a chisel like Paul Sellers demonstrates (a poor man's router plane).
When you're done using this plane you'd still have a chisel.....and a hex wrench.
Second that.
david weaver
They (the LV) are half the price of stanley irons on the open market.
It's hard to justify making an iron like that for $16.
Making a router plane.....
roger lance
Tom.....years ago, I wanted a smaller router plane that could use the stock LV blades (I had a large LV router plane and blades). I looked at Derek's design and because I didn't have the hardware or a piece of suitable stock, I decided to try a design of my own. Admittedly, Derek's plane is better and more attractive. A few years later, LV introduced their medium router plan which uses their stock blades so I bought one.....
Its fun and a challenge to make your own tools.
William Duffield
The fallacy of using a hex wrench is that all the Allen wrenches I've seen are bent orthogonally to a flat, not to an edge. When mounted in a router with the v-groove in the post oriented as in Roger's or Lee Valley's routers, the blade ends up skewed 30° to the natural direction of force. I discovered this many years ago when I built one from a St. James Bay kit. I made do for several years with a blade ground from a cement nail until I finally replaced it with a Veritas router plane blade.
david weaver
The plane that paul makes of that style is a bit of a struggle to use for much work other than chipping out pine between saw cuts.
I know what his gimmick is to get people going (minimal outlay), but such a plane would become difficult to use for fine work compared to any of the decent router planes - especially in with-the-grain work.
Paul struggles with it in his videos, and I don't think it does any of his watchers a service, but that's just my opinion. He's got throngs, and he sells his gimmick (minimal outlay, but come pay for my classes) while accusing others of selling theirs (buy good tools to do good work).
