Shiplap with bead question
Joe in a Cleveland suburb
This may seem like a silly question, but I'm not sure of the answer :\
I couldn't find any old magazine articles or books that would help that I have.
I am playing around/practicing with my little Veritas Small Plow plane.
I'm making a small cabinet that will have ship lapped back boards. I'm practicing with scraps of pine. The ship lapped part was simple. I did 3/8 x 3/8 rabbets.
I thought a 3/16" bead would be nice. So should I put the bead on the "A" board, or the "B" board?
I'm guessing the answer is the "B" board because it would leave more meat so-to-speak.
Right?
Thanks.
Re: Shiplap with bead question
david weaver
A would be easier to bead. There shouldn't be a strength issue with it if the bead isn't too deep.
I'd relieve the corner of B a little where it meets the bead from A so that the bead looks symmetrical. (that's just an opinion and not a reference to historical work).
Ken Martin
I am not certain on shiplap but on old railroad car siding the bead was on the side with the tongue.
Ken Martin
roger lance
"B" is the historical choice and for the reason you guessed.....more stock thickness to support the bead.
Any thoughts on the Veritas small plough as a beader?
William Duffield
I think A" would significantly reduce the strength of the joinery. "B" would be easier to bead if you had the appropriate blade for your combo plane that cut the rabbet and bead in one pass. "A" would require three operations to complete the joint, while "B" could be done in two.
Hank Knight
A sharp wood side bead plane would make beading "B" a piece of cake.
Thanks all
"Any thoughts on the Veritas small plough as a beader?"
Hi roger.
Being that I am not an expert hand tool user, I don't really feel qualified to offer an opinion.
That said... I think it is a nice, well built plane. I have the left handed version with the conversion kit to use wider blades. I also sent it in last year for the modification to the plane's skate to use beading blades.
I've had it for a while now and really haven't used it a lot. But when I have used it it works well and fits my hands. I don't have much to compare it to. I do have a couple old wooden beading planes that I could never get to work well and this Veritas plane seems to work better for me.
Any issues have all been user related and lack of experience on my end.
I would buy it again and have other Veritas planes and tools. As I'm sure you know, it's hard to go wrong with their stuff.
Thanks.
