Paul Sellers dovetail video.......
roger lance
There is a YouTube video called "Paul Sellers | Dovetail Joint with Hand Tools" in which Mr. Sellers demonstrates making a dovetail joint at a woodworking show using only: a pencil, a dovetail saw, a copying saw, and a jack plane.
Its remarkable. The joint fits perfectly including the removal of waste with that copying saw......no chisels, no marking gauges, no knife, etc., etc.
Humbling......and fun to watch.
Re: Paul Sellers dovetail video.......
david weaver
I've seen him do that fairly often. I'm guessing he's using white pine for those and undercutting the back side of the joint a little bit to make sure he has a good fit on the money side.
Still, if you were going to pop drawers together in bulk for shop furniture that might take some abuse, the exposed back side (which you'd never see other than looking in the drawer) wouldn't be an issue at all, and the drawers would be far finer than the lock joint and pinned/stapled drawers offered in most manufactured furniture.
roger lance
Absolutely.....like any good magician, Mr. Sellers is controlling as many factors in his demonstration as he can.....certainly, the wood is easy to work and offers little resistance to being cut.....and, if you noticed, he did not hand over his dovetail for inspection by crowd members but rather held on to it and showed the side he wanted seen (probably did slightly bevel that waste cut with the copying saw to insure a fit off the saw).
Still, in all.....its impressive.....and with a minimum of tools. Its the skills baby!!.....as I look at my LV catalog to figure out what I "need" next.
david weaver
I agree, I still think it looks pretty good, and I absolutely think this is a useful trick. If you and I go into the shop and have to make some utility drawers but don't want to spend an hour a drawer, this is a method that is right down our alley and far more enjoyable than lining up a bunch of butt joints and nailing them, and it will hold together indefinitely, unlike pinned drawers.
I intend to try it, and I was inspired by it the first time I saw it. I even thought about doing my kitchen cabinet drawers that way since they are essentially utility drawers, but I ultimately chickened out.
Stuart Johnson
I took several classes with Paul when he was at Homestead Heritage down by Waco and have seen him demonstrate his dovetails many times. He does use pine for the demos but will also hand it around to be examined.
Gary B.
Indeed, he's a master craftsman no doubt. Another video that blew me away is knocking out an entire box using this method in 8 minutes (Below). It seems the inverse of Frank Klausz's method, but very similar. They both only use baselines, but Frank is pins first.
https://www.youtube.com/watch?v=14RSFkOmncs&index=1&list=PLkx4x7622sKtPJG17ulmjf6v11l_ww2-o
I like Sellers because he's more about the methods and skills than fancy tools.
North of the Border
While this particular video does not show all the faces of the joint, in other live woodworking shows (I have been to two in which he was present), he handed the joint to the audience and it was a gap free joint. No tricks and no shortcuts.
The two dovetail teachers I know cannot cut a joint like that in 5 mins even in pine or any softwood. Anyone who doesn't believe me can grab a scrap and try it.
Rob Cosman can cut as fast but he uses a chisel in his process, dividers, too.
Paul's skills are undisputed in camera or in person. Second to none, if you ask me, as a skilled dovetailer myself.
North of the Border
"I like Sellers because he's more about the methods and skills than fancy tools."
That is what makes him stand out from the rest.
A long time ago, I saw a video about card scraper sharpening by another better-known woodworker/teacher. His process wasn't much different from other sharpening methods out there, except the last couple of steps. He burnished a heavy, bent hook and then used the sharp end of his burnisher to "undo" the heavy bent.
Here comes the finale part that only a salesman would do: He announced that you could buy his sharp ended burnisher to do just that.
Paul encourages people to use "poor man" solutions. In every dovetail demo, he uses a coping saw ($20?) and does not tell you a $130 fret saw would do a better job. Few people can cope saw as level as he does. Try it if you have a coping saw and don't look over the other side to check if you have undercut or overcut from the baseline! His over 45 years (50 now?) of planing, sawing and chiselling are not a paper qualification.
