Knew Concepts saw
Knew Concepts saw
Jack Guzman from Maine
Knew Concepts saw
I just recently took on a project where I had to build six drawers,two of them 10" tall. That was alot of dovetails. When I cut out my tails,I make all my vertical cuts(dovetail sides) then go back and cut just above the baseline with a jewelers saw to remove the waste. For years I have been using a Trojan-50 jewelers saw. It is the only one I could find that allowed turning the blade so the back of the saw wouldn't get in the way of the cut. I find a coping saw to be too crude for this job.
After I finished I got to thinking about these newfangled saws made by Knew Concepts. I wondered if they made a smaller,jewelers saw type. So I checked their website and they had just what I was looking for. 3" Mk IV Heavy Duty Hand Saw with Cam Lever Tension and Swivel Blade Clamps is what they call it. It does everything my current saw does but way better. I got it today and made some practice cuts in hard maple. I can tell this going to be a long and happy relationship. Nice,nice tool.---Jack
Re: Knew Concepts saw
roger lance
Jack.....I recently got the 5" version which replaced a French made fret saw that I had and found to be difficult to use for blade installation, tensioning, etc.
The Knew Concepts saw is a real advancement.....a real improvement.....and I'm, like you, glad I made the switch.
North of the Border
Yes, it is a better saw than the fret ones (but not in price). I no longer use the fret, but I got mine for much less than half the original price as its owner decided hand cut dovetails were not his thing.
Would I have switched if the saw were to be paid for its full retail price? Nah. Unlike the dovetail saw, the fret or coping saw matters little in the final quality of the dovetails.
It has made me a......
roger lance
happier woodworker......
interesting background story......thanks again.
Wiley Horne--So. Calif.
Thanks for the post, Jack. Lever tension and blade rotation are very useful upgrades--makes me want to replace my early version with the one you've got.
What I like about the Knew saw, compared to the 3 regular Jewelers' saws I bought over time (looking for the right one), is how much tension you can get on the saw blade without the frame deflecting. This makes it easy to gang-clamp 2 or 4 drawer sides, make all the vertical slant cuts at once, leave the gang clamped and saw all the waste at once. You get a long way down the road on one clamping.
Thanks again! I wouldn' t have known of this saw otherwise.
Wiley
Using the Knew Concepts (and other) fretsaws
When I first looked at an improved fretsaw, my thoughts were fixed on as stiff and rigid a frame as possible. Perhaps it was that the fretsaws I used up until then were on the flexible side, however, looking back, I recognise that poor technique came into this as well.
The KC fretsaw was a revelation in stiffness and lightness combined, but I recognise now that it's very qualities can help in disguising flawed sawing technique, and that with good technique, it is an even better saw ... and very likely, lesser fretsaws are better than they seem.
The technical issue is a terribly simple one, yet the results for me have been profound. What is it? Simply, let the saw do the cutting. Never force a cut. This is the same technique one uses with a dovetail saw (or a tenon saw).
You can judge the tension on the saw blade by the bend in the blade. Aim to bend the blade as little as possible. I used to try and actively saw the line, and this would cause the blade to wander (like forcing a board through a bandsaw). Now I lighten the handle and let the blade caress the wood. It saws just as fast - but with full control.
This enables one to saw to a mm of the baseline, and that means minimal paring to the line.
Re: Using the Knew Concepts (and other) fretsaws
Don Orr
Thanks for all the great info on this saw. I have been lusting after them for a long time.
Derek-in your photos it looks like the teeth are oriented so that the saw cuts on the push stroke. Is that correct and does it matter?
Thanks for all your outstanding posts!
Re: Don, it cuts on the pull for the greatest tens
John Pappas
Does it really make a measurable difference in tension on this saw, with a frame that is as rigid as it is? I would venture to say that the difference is next to zero.
Hi John
No doubt the frame of the KC fretsaw is strong/stiff enough to resist twisting or bending if the saw was pushed instead of pulled. However, there is another reason to pull rather than push the saw, and this lies with ergonomics. Your mileage may vary, but I do not like using a gent saw (which is a Western dovetail saw with a straight handle). If using a straight handle, I prefer to pull it, as with a Japanese saw.
Don Orr
Thanks Derek-and thanks for all the outstanding project and technique and tool articles you have written for us.
