waxing a dovetail saw
Jack Guzman from Maine
I am building a bunch of drawers. The client wants hand cut dovetails . Who am I to argue? I'm using 5/8" poplar for the drawer sides and cutting both sides at once,clamped together. The sawing was getting a little tedious so I made a swipe along the sides of the saw with household wax. Instant relief! Took all the work out of it. All I need to do is concentrate on steering.
What I want to know is if anyone else uses wax on a dovetail saw. Should I worry about transferred wax affecting the glue? It doesn't take much wax to get the saw sliding with ease.---Jack
Re: waxing a dovetail saw
david weaver
If it's tight and heat is a problem, I either use paraffin or beeswax, and sometimes paste wax - whatever is in reach.
I've never had tails or tenons refuse to hold because of it.
Ron in Sterling, CT
Hi Jack,
I wax all my handsaws with Johnsons Paste Wax. They slide so much easier, and it is a good rust barrier for a while. I have never had any finishing problems as a result of using it.
Ron
William Duffield
Doesn't everyone? I use beeswax or a plumber's candle.
Yes and No
Waxing does work. However, this is usually a symptom that there is insufficient set on the teeth. A smidgeon more and the saw may glide without wax.
joe mohnike
I have used dried out bar soap. Does the same job a wax but easy cleanup.
William Duffield
Be careful with soap. It is hygroscopic, and can attract moisture, and rust your saw plate. Same problem with using it to lubricate steel screws.
Warren in Lancaster, PA
What we call poplar in the woodworking trade here in eastern United States is Lireodendron tulipifera, which is in the Magnolia family. It is a traditional secondary wood, especially in the Mid Atlantic region.
One peculiarity of poplar is the occasional need for lubrication. One can go for months working other timbers, with no lubrication at all on planes and saws, then have some piece of poplar demand it. Sometimes one can get screeching planing end grain. Lubrication does not need to be very much and it does not need to be often or regular. Wax, oil or grease will work.
Re: Yes and No
Good point Derek,however not in this case. The saw cuts perfectly for me but I wanted to double up the sides to speed things up. The extra thickness was more than the saw was intended for and I had to work harder. The extra effort needed was getting tiresome,hence the wax. ---Jack
North of the Border
Yes.
Candle wax for sawing, gang cutting or not as well as for planing.
Soap wax, no as another poster pointed out. For screw lubricant, I use the toilet bowl wax ring.
Ron Pemberton
Ditto, Ditto
Ray
When I purchased LV dovetails saws, they came with the recommendation of not using beeswax. Something related to possibly clogging the teeth.
roger lance
Ray is correct. LV recommends paraffin to allow the saw to run more smoothly through the cut....but, also states not to use beeswax because beeswax will gum everything up.
William Duffield
It seems like it would depend on whether you apply it to the saw plate or the teeth. What would keep paraffin from filling the gullets and sticking to saw dust in the teeth? Sure, it has a higher melting point than beeswax, but a little friction will soon warm the teeth and the wax and start to liquify it.
bridger
Bridger
I for many years used beeswax. When my chunk of beeswax ran out I replaced it with paraffin wax. They worked about the same for me. Never had problems with clogging. You just need a tiny scribble.
