my adventuress into hand tools is opening up a whole world of shaping wood. i currently looking to purchase a few of these items and now i'm wondering how do people typical store them. i image that should not be rolling around in a drawer.
I got a piece of wood and cut file thickness slots in it. Files are on edge in slots. Now I have enough files that I have a 2-story affair with slots cut into it and stored on a shelf. Files are all orderly in these slots by type and length.
Are you suggesting that 'loose in a drawer' is not acceptable? I know for a fact that one can achieve very tight packing in this scenario. You could probably get rid of that second story.
You are correct. Tossed together in a drawer, they will soon come to grief. There's no quicker way to destroy a rasp or a file than to bump its teeth up against another one.
Most of mine I keep in a rack hanging on the wall behind my bench.
The file on the right end is in serious need of a handle. I would strongly suggest you don't use any of them without a handle. You can do permanent damage to your hand.
The rack has a few more files and rasps on it now than when the picture was taken. This can be an issue, as it means extra care must be taken when taking them out and putting them away to keep them from bumping each other. Like other hand tool skills, it takes practice and familiarity with the layout of the rack. I've also added another rack, but it mostly holds chisels and marking and layout tools.
The rasp rack lifts off its support bracket,
and hangs on another bracket
that I can set on my bench or in my tool tray
or hang on the side of my tool tote if I'm going somewhere with them.
My saw files are kept in a roll, offered by Lee Valley.
When I'm working with one or more rasps and files, I often drop them into dog holes on my bench. This only works in cases that the rasp is less than 3/4" wide and its handle is more than 3/4" in diameter.
Another strategy often employed is to put them in shallow tool chest drawers or sliding tills with wooden or plastic dividers, so they cannot roll into each other. I usually attach the dividers to the drawers with hot melt glue, so I can move them around as my file and rasp arsenal evolves. This strategy works for chisels and carving gouges as well. The most important layout consideration is to make them shallow enough that you can only put one layer of tools in each drawer.
I store them in a metal tool box on one of those rubber liners. Mine touch each other sometimes, but they take a lot more damage from actual use than they do touching each other (the tool box doesn't move - if it was transported, it would be a different story). Well, that's about 1/3rd of the files - the rest, I store in a cloth bucket boss - I have such a large pile only because of their usefulness in plane making (metal and wood). My shop is humid and from time to time, one may get discolored from very light rust/staining, and then I address it right away. I've never had rust on teeth that was of consequence, though.
I'd make a joke about stacking them on top of each other in a humid place, but I'm afraid someone might take that seriously (if you've ever seen a stack of old files that were touching each other unsupervised for a long period of time, you'll recall how catastrophic that can be).
Biggest threat to them is just like planes - out of sight out of mind for a long period of time can lead to digging out something you want to use only to find that it's ruined.
I've made sleeves for each of my files and rasps from heavy paper and tape. When I store them, I clean them first, slip the sleeve over the business end and lay them in my file drawer. They don't rattle around much in there drawer and the paper protects them form whatever incidental dings and scrapes that occur.
I have my most used files in a rack close to my work area but I have two drawers full of files floats and rasps. They don't rattle around and they don't rub against each other. The drawer is lined with a rubbery sheet and I lay them side by side but not too close. I imagine if the drawer was in a moving vehicle it would be different.---Jack
