Re: Lowest honing angle PM-V11?
I've heard that A2 is best hone at ~35* because it tends to get edge chipping at lower angles. Not so for O1 from what I understand. I've got a few PM-V11 blades but I haven't seen definitely if there is a honing angle below which the edge begins to break down more quickly?
So how low can you go?
Tony, I think that you are referring to plane blades, since you posted on Sawmill Creek that you had purchased a Veritas Custom #5 1/2 with a 40 degree frog. The context is important.
Bevel edge angles are a trade off between "sharpness" and durability. Lower angles penetrate more easily, while higher angles hold an edge better. However, when you have a plane blade around the 25 - 35 degree range, the amount of extra penetration is moot, but the longevity of the edge is not.
In regard to the latter, the higher the bed angle, the higher the stresses on the blade edge. Conversely, the lower the bed angle, the lower the stresses on the bevel edge. I have compared a low angle plane (Veritas Shooting Plane, 12 degree bed) with a higher, common angle plane (LN #51 shooting plane, 45 degree bed), and the LA plane kept cutting long after the BD plane. Different blade steels made no difference here. In fact, a BU blade with a 25 degree bevel far outlasted a BD 30 degree edge.
Link: http://www.inthewoodshop.com/ToolReviews/LVShootingPlane.html
In my opinion, no BD plane blade should be honed below 30 degrees. Some argue, like Steve Elliott, that the most durable angle is 32 degrees. I think that David Charlesworth would suggest 35 degrees.
It's not that simple. One cannot simply lower the bed angle to reduce the stress on the blade edge and expect greater longevity. There is a limit how far one can go before the clearance runs out. Generally, a clearance of 7 degrees is considered to represent the danger zone (too little). The clearance angle is calculated from the difference between the bed angle and the bevel angle. For example, the 40 degree bed of your Custom #5 1/2 with a 35 degree bevel angle would leave 5 degrees of clearance. Too little. A 30 degree bevel angle would leave 10 degrees clearance. OK. And a 25 degree bevel would leave a 15 degree clearance ... but the edge would not last as well as the 30 degree bevel.
I have a Custom #7 jointer with a 40 degree frog, and a Custom #4 smoother with a 42 degree bed. Both have PM-V11 blades with 30 degree bevels. The 10- and 12 degrees, respectively, of clearance are fine. I obtain good longevity of cutting.
The advantage of a low cutting angle is that it leaves a cleaner surface than a plane with a higher cutting angle. This is more noticeable on softer woods and those with tight grain. Going lower than common, especially in a smoother, makes sense.
The advantage of the 40 degree frog in the #7 jointer is that it can shoot endgrain as well as a BU plane with a 12 degree bed and a 25 degree bevel. Plus, with the chipbreaker set close to the edge, this plane will handle any potential tearout.
The disadvantage of the low angle frog is that setting the chipbreaker is important, and the lower you go, there is an added sensitivity to its placement. Unless you are proficient with setting a chipbreaker, or plan to be, then go for the relative safety of a higher cutting angle (a higher angle frog). Many will not see the difference between 42- and 52 degree frogs, especially after a finish is applied. Going low is for the extremists!
