Chagrined
Chagrined
Chagrined
Joe shelton
Finally decided to try sharpening a saw yesterday. Started with a 9 pt Disston Townsman, so that I'd not be ruining an heirloom. Filed it rip, and it worked so well that I picked up a grungy Disston Junior and embarked on a crosscut attempt. More tedious, but I was feeling good. Dialed in a new saw set, set the teeth, and was surprised at how quickly and smoothly that went. When I started a test cut, all was well. Briefly. Quickly was binding badly.
The saw set I have is adjusted with a dial marked, not according to number of teeth, but an arbitrary scale in which a large number yields a very small degree of set.
At least I found out before I discarded both the poor little saw and the bassackard saw set...
Re: Chagrined
Change the set?
If the saw binds, you can play with the set to give you the clearance you need. It might not be much at all.
Re: Chagrined
Re: Change the set?
Joe shelton
Yes, thanks. I plan to try that this weekend. Just groping my way thru...
Re: Chagrined
Re: Change the set?
Jim Matthews
If the setting tool is fiddly, the same process can be done with a fine nail set, light hammer and a backing block.
The plate must be raised off the bench high enough to get the handle clear of the surface.
I've done this in a pinch, and it works.
Re: Chagrined
Re: Change the set?
Joe shelton
Thanks, Jim. I may try that on the next one.
Joe
