ADVERTISE HERE - FREE TRIAL
Cleaning Old Stone
Cleaning Old Stone
Cleaning Old Stone
Stuart Johnson
I picked up this stone at a shop for $5.00. It appears to be completely gummed up I think probably for old oil. How do I go about cleaning up so it can be used? It appears to have two gritss. Any idea what grit they might be?
Re: Cleaning Old Stone
Hank Knight
Run it through your dishwasher - seriously!
While SWMBO ain't at home!
(Message Deleted by Poster)
Stuart Johnson
Life is too short to try running it through the dishwasher so what is another way to clean all the crud off it prior to flattening?
So....how do you....
Brian Roberts
flatten them?
Considering the varying hardness of stones....must be something like maybe diamond powder/paste?
Why clean it at all?
If you are going to grind the thing flat why are you worried about cleaning it? Grinding is going to expose a fresh surface.
If you are not going to grind it flat, add lots of lubricant and use it. Using it well lubed will "clean" it.
Stuart Johnson
Thanks for all the response. I'll try the water cleaning to start with and go from there. The reason to clean prior to determining if it needs to be flattened is the old oil has dried to a thick tar like substance.
power washer ?
Joseph Piotrowski
i'm not sure but might be better than a dishwasher ;)
Re: power washer ?
Joseph Piotrowski
or a self serve car wash if you don't have a power washer
david weaver
A soak in simple green (diluted) is the common starting point on the razor board.
Most of those are natural stones that aren't oil impregnated like your stone, though. If you run the oil out of that stone, it will soak your honing oil in and let it through the stone (as in, the oil will go in, and then come back out) in an undesirable way.
The fix for that if it happens is to soak the stone in heated vaseline, which will not run once it cools down.
There are two ways the carborundum stones become problematic - first, if the stone is a hard one, the particles at the surface become dull because they don't turn over fast enough, and there may be some loading issues. Second is a soft stone where the particles fracture easily, don't get flushed away (not enough of the right kind of oil is used when using them) and clog the pores / get compacted into the stone.
I don't know what the general opinion is of simple green, but it is cheap for a gallon of it and can be used in various dilutions for just about everything. I heard someone claim it was toxic at one point, but only once. That and the "la's totally awesome" cleaner at the dollar store will clean just about anything together.
Question
Wiley Horne--So. Calif.
I have a black hard oil stone, gotten years ago from Hand America. I use water stones and some diamond for the most part, but I would like to rejuvenate this black stone. What about abrading its surface with a 400g fixed diamond stone? What about simple green?
Wiley
Re: Question
david weaver
Diamond stone should be fine, and simple green should work, though anything would since you'll be taking the top layer off of the stone.
Wd40 also works well. I've generally used WD40 for out of flat stones, and anything I guess - always have been in the habit of refreshing the surface of any significantly used oilstone because they're never nick free (but they stay nice after that initial flattening).
If the 400 seems suspended on swarf, turn it sideways for some of the strokes when lapping the stone.
Stewie....can you describe...
Brian Roberts
your flattening process?
Do you use a glass plate?
What silicon carbide grits do you use...and where do you get it?
Water for lube during flattening?
I have a large cast plate that I ground to within .0003 of flat in all directions that I made to use for flattening stones....and whatever else will fit it's 6" x 21.5" size (actually made two of them at work...one for them and one for me.....really great having access to the Okamoto 12 x 24 grinder!).
Our plan was to use diamond grit with the cast plates ....but haven't gotten to the point of getting any abrasive.
Thanks so much for any info you can pass on!
An easeir way?
Seems like there would be some sort of diamond tooling that would mount in a milling machine. Or, using a silicon carbide abrasive on whatever you ground the cast plate on, grind the stone like you would grind hardened steel.
The problem with a glass substrate is that glass is too hard. The abrasive doesn't embed in the glass and become fixed. To get any abrasive action the abrasive particle must be fixed relative to the motion of what is to be ground. Hence, it mostly rolls around in use. Silicon carbide fractures easily so most of the abrasive becomes crushed in use.
Never tried it, but one of the rocks used for kitchen counter tops might be better than glass. The right rock will be a bit porous, or it might have some softer minerals in a hard quartz matrix, and might fix the abrasive better.
I still find it astonishing that the superior properties of a diamond abrasive are used to flatten rocks which are in turn used for sharpening, rather than cutting out the middle man and using diamond to begin with. If I had access to a surface grinder I would not fret carry-over contamination. I could then use a fast cutting diamond paste for initial edge preparation (15 micron) , refine with 1 micron and done.
Easier, but more expensive....
John in NM
Sure, there is plenty of diamond tooling for all sorts of industrial machines... float glass is far cheaper and readily available.
Even a large chunk of flat cast iron is beyond availability for most of us in areas that don't have an historical woodworking industry that is now defunct leaving large pieces of cast iron in junkyards. All you can find around here is old cars.
I once tried a tile from Home Depot, a polished bit of diabase rock (ie black granite), thinking that the relatively soft minerals in it would work better than glass and that the mica minerals might catch the cutting media and work more like cast iron. In fact, it worked just about as well as glass.
Now a scrap of Corian or similar plastic solid surface material might just be worth a shot. However, like sandpaper on glass, I suspect it's going to dub the edges more than I would like.
William Duffield
I have some dumb questions about "manufacturer's oil fill:" If you are going to apply an oil lubricant to the cleaned stone anyhow the first time and almost every subsequent time you use the stone, what difference does it make if you have removed an "excessive" amount of the original oil? Natural oil stones don't need an oil impregnated by the stone cutter, so why does a synthetic carborundum stone?
Since carborundum stones are made of sintered silicon carbide crystals, I don't think I understand the process by which degradation in a dishwasher could occur, unless the abrasive included in dishwashing detergents is itself SiC.
While I'm at it, I'll ask some related oil questions: Am I damaging my oil stones by using a 20 weight or 30 weight SAE non-detergent motor oil as the lubricant? How about using kerosene or WD-40 or USP mineral oil, which people have reported success with? Can the dish washing detergents in hot water degrade the abrasive of the stone?
Re: Stewie....can you describe...
William Duffield
Why use a water-based abrasive slurry on an oil stone?
In a word...
John in NM
"no" :D
You have nothing to worry about.... run 'em through the dishwasher if you like and the wife will let you get away with it :D Won't hurt a thing. The detergent is fairly caustic as soaps go and will eventually etch your glasses, but carborundum (oops, said SiC the first time!) is much tougher than those glasses.
I use WD-40 on oilstones, I like it better than light oils like 3 in 1. It all works though.
There are many ways to do things! Not just one!
