Regarding sharpening
Wiley Horne--So. Calif.
Hi Roger,
Coupla opinions on your sharpening question. I'll stick to sharpening and honing here; grinding is another matter.
The out cannel gouges can be sharpened on whatever stones you use for your other tools--it's a matter of developing a rolling action to do the sidewise sharpening, and practice. However, you also want to be able to work the upper side where the burr forms, and this wants a slip of the proper size, or else a dowel of the proper size wrapped with either an abrasive paper (such as the LV microabrasive film) or embedded with an abrasive paste. Lots of people like to put just a few degrees bevel on this upper surface (I do), but opinions may vary, and I'd like to hear Warren's view of this.
The in cannel or scribing gouges are the other way around. Here, you need slips of the right size, or a properly sized dowel or other round object (even a drill) with abrasive film wrapped around it or abrasive paste embedded into it--to work the primary bevel on the inside. Then get the burr off the back side on your stones with the rolling sideways motion, but no bevel on the back of the scribing gouge--keep the back straight.
This is just what I have learned as an amateur to do on my own. it works. However, I would much like to hear Warren's views on sharpening the two types of gouges.
Wiley
