Have a question? Ask Woody!
Questions about Titemark blades
Joe shelton
I'm clueless about the reverse marking blade, and vague about the scoring blade. Others are clear and appealing. Anyone using the reverse or scoring? If so, how?
Thanks.
Re: Questions about Titemark blades
Hi Joe
I have both Tite-Mark and Veritas reverse wheels. They are similar quality.
Essentially, a reverse wheel is used, as one of a pair of wheels, in a mortices gauge to provide a bevel direction that leaves the outside square (and not sloped). The wheels would have opposing bevel faces.
I built this gauge to use the TM wheels ..
The thing is, they are unnecessary. There are Japanese knife mortices gauges, such as a Kinshiro, where the bevel direction that is scored is very noticeable. These blades are thick, and leave a wide imprint. However, on a wheel gauge, the line created is so fine, any bevel direction is difficult to see.
In addition, I find that the reverse wheels need to be especially sharp to cut smoothly. I am not sure why, but as soon as they dull, they struggle to cut - where a non-reversed wheel continues cutting .. a touch wider, but still smoothly.
Lastly, the reverse wheel is used as one of a pair, and therefore together on the TM gauge. This does not work well when scoring mortices lines. The wheel gauges leave a fine line at the best of times, and when used as a pair, the lines are faint. The Veritas double stem gauge gets around this by enabling the two wheels to be used independently.
I like wheel gauges, and tried hard to like a double wheel for mortices, but eventually gave up on this ... and, therefore, the reverse wheel.
Joe shelton
Thanks, Derek. I should have been able to figure that out, but I appreciate your remarks.
