dovetails,Rabbits and dado's oh my!
Joseph Piotrowski
i'm moving along on my shop cabinets. i spent the weekend getting the pieces cut to size. i hand jointed one side of each board. i soon found out a 9.5" wide board can become a 9 inch board
but once i did that i cheated and rip it to size on the table saw. i don't really have a sufficient hand rip raw. i did want to use hand tools, but my hand tools and skills are lacking so i'm allowing it
. in the future i'll have my band saw setup and that would also work well.
i cut the pins on one board and remembered i wanted to rabbit the backs. so i test cut a few rabbiots on scrap, using different methods. i figured out the best method with the tools i have and could actually get a decent rabbit.
it takes a while as i have to sharpen and setup each tool i try to use. not to mention figuring out how to use the workbench i have to get it done.harbor freight special.
i also had to fight the urge to leave the rabbits alone after test cuts and buy a vertias skew rabbit plane.
i soon tossed chopping them out with a chisel method.i settled on using my Ulma wood body shoulder plane over a skewed rabbit plane(old wood one). the ulma has a cap iron and that seams better IMO.. i tuned cap and iron up (free hand) hand it wasn't as awesome as the YouTube vidoes but now after 14 feet of 3/8 by 1/2 rabbits i'm comfortable enough to skip buying a tool for now
for this cabinet i'm just mitering the back end where the groove is and cutting dovetails for the rest.
the next case i'm stepping up my game with shouldered dovetails and mitering both edges. should look nice and good practice.
I've already cut a bunch of test dado's and have a process down that should be ok since i'm only doing a few. one or two per case.
dovetailing is a pain. literally. without any face/leg vice, i had to use clamps to hold the wood. but bending over was no joy.. 2 advil later i decided this has to change. ideally i want to have a benchcrafted moxin vise but that cost more than my whole bench. so i need to rig up something to raise the height and be cheap to construct. baby steps
so now its build something to allow me to build what i wanted! beginning are rough until you get all your shop squared away!
i see a proper workbench in my future.
thanks for reading my ramblings. i though id share some progress as many of you have given me ideas and tips.
thanks,
Joe P.
