Re: Any Ece Primus plane owners?
TomD
I have two smoothers, and a jack, I don't use them much either, but that is not a knock on the planes, I have always mostly used my own planes, but over 35 years or so, I buy the odd other plane to try something new out. So there are a lot of planes around at any one time.
There is no such thing as planes that are more advanced or better than the wedge kind, that was the apex of development, nothing since is better. But the mechanical adjustments work very well, and the ECE planes are amazing devices, wholly better than the Bailey style over her. It is always worth considering that the Germans still have an apprenticeship system, people over there who charge for woodwork are all at a higher initial level than anything you see over here. I was walking down the road in Bremen at one point and a shop was being refitted and the whole thing was full of every piece of gear Inca made, as it is all portable. Similar idea today would be the excellence of Festool. So these are the planes they use, they are good enough for anything you may need them for.
I have a slightly off assessment, because at that time I replace the blades in every western plane I got with Blue Steel Japanese plane blades, which makes them super charged. For one thing one doesn't need to resharpen as often.
I have to agree they are a little fiddly, that is just a manipulation deal. The way the blades are retained is very well designed, rather than the clumsy and bulky lever cap, the blade is adjusted for depth and firmness to the body by a spling loaded T that fits through a slot in the blade assembly. The strust on this unit is paraller to the sole and to the rear. Since the bed is angled this creates a vector up the bed angle, so the dept adjust works on this T. It is an excellent system, except when you go to take it apart, you need to back off both knobs just so and rotate the T in the right direction. This is awkward when first attempted, so it is the kind of deal you want to practice in front of the TV for a while until it become neat and second nature.
So on the question of whether these are tools for beginners, well there is nothing high end about the skills required to use them. I have never really had any trouble with the wedges, but people do find them tricky, this is not that. In use you get superb adjustments, zero backlash on adjustments, zero interference with the chip escapement that no other plane can claim, and you get the efficiency advantages of a wooden plane, it's light weight and low friction. I am not a fan of the look of the smoothers, but the horn arrangement is very comfortable and very usable in push or pull. So really the only downside is the tricky manipulation of parts during disassembly, it isn't hard on the hands like some planes. It is like starting a chainsaw, you sorta need to have read the starting instructions, and follow a procedure. If you take a few minutes to familiarize yourself it should go smoothly. It isn't an expert woodworker thing, just a mechanism.
The only thing really against them is will you be happy with them. If you follow the mags, blogs, videos, etc... These are not the tools you will see. They might be better but will you feel the need to make another purchase later? Even Franz Klausz gave them up because they were not the planes his students had. The videos I found on Youtube were in German.
