Re: How are you doing cockbead
Wiley Horne--So. Calif.
Hi Bill,
I've done it as you describe. For example, in this little table:
http://gallery.woodcentral.com/wp-content/gallery/wiley-horne/img_20150211_0011.jpg
But I didn't like how the work went. Because I had to plane the 3/32" off top and bottom (these are full width cockbeads, like you use), which seemed like a lot using the only rebate plane I had, which was a large shoulder plane, and worked the whole time not to ding the drawer side, though I still managed to when I was almost done. And had to fix/hide that ding.
So now I prefer to make the top and bottom 'pre-rebated'--I make the rebates as part of the drawer-making, and then add the cockbead strips at the end, leaving the cockbead just slightly proud and planing back to a fit (using 1-thou cuts as described above).
Here's an example:
http://gallery.woodcentral.com/wp-content/gallery/wiley-horne/img_0985.jpg
http://gallery.woodcentral.com/wp-content/themes/twentytwelve/image-popup.php?imgId=463
In this case, the drawer fronts are thick veneer (3/16"). There is a 3/4" satinwood structural drawer front, which I through-dovetailed to make the box. Then glued on the 3/16" ribbon-stripe satinwood front, with a plain but quartered surround (which is lighter); then cut in the ebony stringing; then laid on the ribbon-stripe cockbeads. The cockbeads were laid into rebates built into the work in the making. Of course, this took careful test-fitting, and very careful gluing, to make sure it all came out right.
Wiley
