New WoodChat!
Tools of the Dovetailing Trade
In between batches of drawers I gathered up most of the tools I was using so that I could clean the bench and swap in the 2nd case. I was surprised at how many tools I was using. And not shown is a shooting board and maybe some other stuff I have forgot!
Drawers are done. They still need to be fit but the plane is too dull to pick up a shaving. After sharpening I need to glue up a top.
I debated on whether to include the swirly grain in the bottom drawer. But this figure complimented the lesser figure in the one above it and I decided to include it. In each case the drawer fronts for each case are from the same board.
Re: Tools of the Dovetailing Trade
Answers
Here is the run down:
Marking gauges- one set to drawer thickness and the other set to length of front pins and tails.
Three squares. One set at 5/16”, the distance from edge of drawer to start of half pin. One set at 11/16” the distance from bottom of drawer to top of drawer bottom. (used for locating bottom half pin in the back board) The 3rd is for running along baselines to see they are flat and the depth of the pins in drawer front half blind is ok.
Four chisels. I need these sizes for various places.
Spoke shave- for making top edge of drawer back concave so it doesn’t ever drag on back divider
Tiny Japanese saw. Removes that pesky corner waste in the pins,quickly. I waste out what I can with band saw.
Pencil, the pen is missing in action, - for marking vertical lines to be sawn for pins and darkening scribed baselines as needed.
Saws- 0ne rip that is dull as a hoe for sawing pins and tails.. One cross cut for cutting pin waste from sides. (I have come to like the LV saw, Excellent value) The rip is too dull to get good cut here. Must sharpen when I get to it.
Carving knife- Used sometimes for marking and also for removing those pesky whiskers that hide in the corners of pins and tails.
Marking knife- for marking precision lines as needed, for example on ends of stock
Divider- for stepping off tail locations
Spatula – for spreading glue
Feeler gauge- Handy way to measure drawer clearance around front and top. I set it at 0.032” and remove what ever is needed to get this gap on the side and top for initial fitting.
Black Mallet. First tool I ever bought with spending money, when I was about 12. It is just a dandy weight and balance for chisel tapping as needed. I do not like the sound of wood on wood.
Gauge block- Use to establish angle of saw for sawing tails. I don’t mark vertical lines. I align the block with a prick point from the divider, position saw on its end, and saw away. It’s quick and good enough to establish the dovetail angle.
Planes, shooting board etc. missing in action.
Brian Holcombe
The cabinets look nice Bill!
That is quite a a number of tools, which mallet do you strike the chisels with?
TomD
The one that jumped out at me was the spokeshave. That is clearly a drawer-making tool and not a dovetailing tool. You can do that with a hand plane should anyone feel they are at a disadvantage without a shave. Shaves were some of the very first tools I bought as I made paddles first off.
I like the design of the side tables, as your incredibly productive production continues.
I use a Japanese saw as a one stop tool for assessing flat and true in dovetail joints (mainly a quick check that there aren't any fibers left over from chopping that might fault the joint on closing). I don't do a dry assembly so I do check. If while I am in there there are any fibers that need trimming the saw is already there. So use knives but this has always worked better for me.
"That is quite a number of tools, which mallet do you strike the chisels with? "
While working on the drawers I am surrounded by my lifetime of tool collection. When a need arises I reach for whatever best meets it. After two drawers done I too was surprised at the tools that had collected on the bench. I have a huge bench so I tend to just lay stuff on the bench after use and clean up when I am done.
Perhaps the unusual tool is the feeler gauge. I find it handy to stick it in the drawer gaps and run it around the gap to estimate gap size and whether it is initially big enough. I target the 0.032 blade for the drawer width gap regardless of drawer size. I target a minimum 0.032 for the height gap and then adjust later depending on drawer height when I am cleaning up the drawer in final fitting.
I don't mean to imply that I target the gap at 0.032 +/- 0.001". I use the blade as a "go/no go" measurement. The gap must be at least 0.032 with not much excess gap. If the feeler gauge binds or doesn't enter I mow off some wood.
I bash as needed with the black mallet, explained in reply to Derek. Sometimes I use a home made brass hammer sort of like your Japanese hammers but I have gravitated back to the black mallet. I don't like wood mallets.
Michael Brady
Don't let the anarchists take your tools away! You probably use no more tools than most to make your drawers. I question only the shave because I can't see the need for it, but what do I know? I never have all of my tools out on the bench, but if I did I might have those and a few more. What does it matter if the results are good? And, by the way, the result seems to be very nice.
spoke shave
I shave the back of the drawer concave so it won't ever drag on the back divider.
An idea that I find really clever
Re:Drawer front
David Charlesworth
I like to shave the inside of the D/F bottom edge hollow, so that it will not clunk against the rail or shelf, when the running surfaces wear a bit.
David Charlesworth
