Discussion-Engineering the bottom of case goods
I hope this post results in some comments from others that build case pieces.
In a typical case piece like a chest of drawers there is a traditional way to construct the base and feet. As shown in the sketch, drawn by our Sgian Dubh, the case is assembled with a panel dovetailed into the top and bottom of the case sides to make a box. A frame is assembled that becomes the interface between this box and the feet, both of which are screwed to the frame.
This construction is shown in real life in this cherry chest of drawers. The frame and bottom trim are in the foreground and the case with its dovetailed bottom panel is in the background. I can think of two advantages of this construction. The panel dovetailed into the case top and bottom restrains the case sides to keep them flat. The grain of the feet and trim molding runs parallel to the grain of the frame. The only cross grain issue to contend with is the joint between the case sides and frame. Are there other advantages for this construction?
A second approach is to extend the case sides to the floor and wrap the trim around this base. The advantage of this construction is that it is easier to accomplish and the integral feet are stronger. Gluing the side trim to the front of the case and nailing it to the back accommodates changes in the case side with humidity changes. A disadvantage is that nothing holds the bottom of the case sides flat.
I have made case pieces both ways and remain unsettled what to do with future pieces. Anybody have some experience to add to the discussion?
