New WoodChat!
Continuous Arm Settee build
Jack Guzman from Maine
I love the continuous arm windsor. It is by far my favorite chair. After having built several rockers in this style I came upon a picture of a settee built by Curtis Buchanan. Caleb James talks about it in his blog. http://kapeldesigns.blogspot.com/2014/04/windsor-continuous-arm-settee-plans.html
You can make this chair using Curtis' continuous arm plans. You just need to modify them a little.
I got the plans and I found a suitable blank for the seat. this is the seat blank after planing.
Next,I made a seat pattern out of some thin plywood.I used the seat pattern from the plans and added 20 inches to the center. To get the spindle hole locations I used a divider set to the spacing of the three center holes in the plan and adjusted to get even spacing between the center holes in the two halves of the plan. The center spindle angles are all the same as the center one in the plans. The center legs were simple to figure. Put then in line with the outer legs and to get the drilling angle use the rake angle listed in the plans with no splay.
The center legs were a little tricky to make.Peter Galbert contributes here to clear this up. http://chairnotes.blogspot.com/2009/04/more-legs.html
Now that I had my plans all made I needed an arm bow. More on that later. I got to get back in the shop.---Jack
Re: Continuous Arm Settee build
More Continuous Arm Settee build
So now my problem was the arm bow. The arm in the continuous arm plans is 59 1/2" long. I need to add 20"for a settee so I need a piece of oak 80" long. I don't have anything long enough so I have to get a log. I need it anyway because my supply of oak splits is running short.So I went to a local log yard and bought a veneer grade red oak log 10' by about 18" thick. ---the log
---a look at the grain
---getting closer
---shaved to size,I'm shaping the arm before steaming
---here it's almost done ---in the steam box
I have to bend it in two steps. Bend one side,let it dry completely,steam other side,bend.In the picture the right side is bent and dry. The left side is in the bending form. I made a holder for the already bent right side to keep it all in proportion.
Arm bow is done it's time to prepare the spindles and put them in the kiln to dry. While they dry I will carve the seat and drill my holes. Next post.---Jack
Re: More Continuous Arm Settee build
Thanks for posting. I remain in awe of chair making.
I didn't know that oak grew in Maine. I never saw an oak in the woods in central NYS. Maybe the farmers cut them all before 1800?
We have alot of red oak up in this area.Oaks and Maples are the dominant hardwoods. Not so much white.---Jack
Wonderful, Jack! This is one of my favourite designs. I have aspirations to build one ... in my dreams. Don't skimp on the details in the coming posts.
Brian Holcombe
Awesome thread Jack! Watching with great interest.
I am at the most critical stage of windsor chair making. Drilling the holes.These holes define the positions of all the elements of the chair. I prefer to drill all the holes in my seats before carving. It makes it easier to get accurate angles.I use a pair of mirrors and sight lines to do this. I tried taking pictures of the process but I'm no photographer and mirrors make this difficult.This is the best I could do.
I bought some 12"x12"mirror tiles and made holders for them with blocks of wood. The blocks are heavy enough to hold the mirror standing at a slight backward tilt. Using a sight line from the hole I'm drilling I place one mirror at the far end facing me,the other I place beside the hole at a right angle to the line. I place a square on the line and a bevel set to my desired angle in front of the other mirror. Then I line up my drill with both mirrors at the same time and drill my hole.
It is a tricky maneuver but it makes for accurate work if done right.
I drill leg holes with an auger bit and stop when the point comes through the bottom. These points I use to make the bottom sight lines for tapering later. I finish drilling the hole from the bottom after drawing my lines.The spindle holes I drill out with a spoon bit. I like a round bottom hole for spindles and the spoon bit makes a hole that matches my tenon rounder in diameter.
The next step is to carve out the gutter that defines the spindle deck. Once this is done I firmly clamp my seat and start carving the seat bottom.More on this in the next post.---Jack
Carving the seat. I drilled a series of 1" deep holes with a 1/8" bit(any size will do)3 1/2" in front of the gutter. These are depth holes. I hollow to them and stop. The object here is to remove alot of wood. I usually do this with my scorp or hollow plane but in this case I thought I needed to use the adze first.
Ideally the adze should be used cross grain. This was unpractical in this case so I tried a hollow plane that I converted from a flea market smoother. It worked better for removing alot of wood following the grain. I finally reached a point where the scorp was useful.
Now that most of the material was gone I could start cleaning up using my travisher and scorp. Here I marked the front of the seat for carving.
I carved the front down to the line and smoothed the transition from the hollow to the front leaving the top of the front legs high. I then flipped the seat over and carved a slope to the line at the front from about 1 1/2" back from the edge. Then I rounded the back. The next step is to taper the leg holes so I need to discuss making legs and stretchers. Next post.---Jack
Larry Barrett
Jack, I see you are using a 'bodger' style shaving horse, as opposed to a dumbhead style. Have you tried both? Assuming you have, what do you like best about this style?
Thanks for the informative post.
I got the pattern for this horse from brian boggs. Before this I used a leg vise. I'm thinking about building a dumbhead style. This one has some restrictions. With longer pieces or curved pieces it is difficult.---Jack
Bruce, a MN Galoot
Do you split out and shave your spindles a la Curt Buchanan?
And where did you get that travisher? Does it work well on dried hardwood, or do you use only softwood seats?
Very nice work and great tutorial. Thanks, Jack.
Because the outer legs are splayed and the center ones aren't, if all three legs in a row were the same length,the center one would be further from the plane of the seat bottom than the other two. These pictures show how I solved this problem. The rear legs are splayed 12 degrees. The fronts are 15. In this first picture I'm marking a line 12 deg. from the edge of a piece of plywood for the back leg. I did the same with a 15 degree mark for the front. In the next picture I'm placing my pattern for the front leg on the 15 degree line. This last picture shows me placing a square on the edge of the board.I find the high points of my pattern (the end ,the two grooves and the point where the seat taper is widest)and place a mark on the edge of the board where the square hits these marks. The edge of the board will be the pattern for the center leg.
I turn my legs out of green wood. After turning I need to dry the tenons. I don't dry the whole leg. I made holes in the side wall of my kiln to dry chair leg tenons. It takes a couple days. (one of the legs is in use on the bench)
Once the legs dry I refine the tenon taper on a lathe and ream a taper into the mortise in the seat bottom to fit the leg.Each leg is fitted to it's mortise to a set depth measured from the upper ring on the leg with a set of dividers.
This picture shows the reaming setup. I don't use mirrors for this. I transfer the sight lines to the bottom of the seat while the holes are still pin holes from the point of the auger. I drill the rest of the way through from the bottom. I place a square on the line close to the hole. My reamer is a 6 degree taper and I need to reference my bevel off the edge of it. So I subtract 3 degrees from my leg angle and set that on the bevel. Now I start to ream checking my angle with the bevel and sighting down the line at the edge of the square and making sure the point on the end of the reamer lines up with it.
If you want a clearer view of this process Curtis Buchanan goes over the whole process in his videos.
Once all the holes are reamed and all the legs are fitted I need to find the stretcher lengths and drilling angles for stretcher to leg joints as well as center stretcher to side stretcher joints. I do this with rubber bands and a protractor. This is a picture of my setup. At this point I measure between the front and back legs to get the side stretcher lengths . To get the center stretcher lengths I flip the rubber band going front to back so it crosses itself in the middle. I do this on all three sets of legs and measure from x to x.
Putting the rubber bands back like they are in the picture I measure all angles following the lines where the bands cross inside the leg structure.The protractor is 12". I couldn't find one to buy so I found a picture on the internet and printed it on a piece of card stock. I wish it was stiffer but it works. To get stretcher to leg angles I find the centerline of each leg and find the angle from that line to the rubber band.
Remove legs. Turn stretchers and put in the kiln.I wrap foil around the center of the side stretchers so only the tenons dry. At this point I finish shaping the seat and start making spindles. Next post.---Jack
Yes, I split and shave all my spindles. The travisher I bought at Woodcraft in Newington NH. I believe it was made by crown tools of Maine.---Jack
Making spindles is pretty basic stuff. I cut a green log of red oak to 24". I split it open to ease tension and then using a froe I rive 1"x1" blanks. These I even up with a drawknife to 3/4"squares.I bring them in the shop and let them dry a week or so. I need 24 for this chair.
Then I cut them to the lengths I need and rough out my dimensions,tapering them to 3/8" on one end and 5/8" on the other. Once I get my dimensions I cut the corners creating an octagon.These I place in the kiln to dry completely.
I determine dry with a scale. I place each green spindle on the scale and measure the weight in grams. I write this on the spindle.I do this several time a day until the weight stays the same. Then I know they are as dry as I can get them. Once my spindles are dry I smooth out all the edges to make them round and then use a tenon rounder on both ends. The bottom end I use a hand held 1/2" dowel /tenon rounder I got from Lee Valley to match the mortises in my seat. The other I use a 5/16" rounder I made to match the bit I use to drill the holes in the arm.
I'm getting a bit ahead of myself here. Before I can size the spindles to the seat I need to assemble the underside.
By this time my stretcher tenons are dry so I drill my mortises and size the tenons on the lathe with a bedan and sizing tool set to the size of my drill bit.
These have to be dead on accurate. If they are slightly loose they will come apart. If they are slightly tight the legs will split when I assemble them.(I have done both)
I drill with a cordless drill using a holding device I built according to one Curtis Buchanan uses in his videos.
The picture shows the setup for drilling the mortise in a leg. I set the bevel to the angle determined earlier. A mirror sits in a groove on the back ledge of the device and a rare earth magnet holds the bevel on the ledge.
Once I get all my holes drilled I glue the underside together and after gluing the leg tenons into the seat I insert wedges in the top of them.
The process is tricky. Curtis shows videos of how he does it. I'm not going to go into that here.
I use liquid hide glue for all my chairs.
After this step I level off the bottom of the legs and then cut the tops of the leg tenons flush with the seat using a shallow gouge. ---Jack
Watching a pro do it...scary
We had a chair maker, not Curits can't remember who, do a seat at a meeting some years ago. He spread a tarp on the floor and standing on the blank proceeded to chop away the waste with the adze or something similar. Chips flew as he chopped beside is toes. It was breathtaking to watch. We were all amazed how little time it took him to rough out the blank. Curtis is quick too but he proceeds in a more refined way. He easily whacks out a blank in the time of a club meeting. It's fun to watch.
Re: Watching a pro do it...scary
I'm still clumsy at carving out the seats. I've done quite a few but I'm still figuring out technique. When I have extra bucks to spare I'm going to get a good hand adze and try it the way Curtis does it with the blank on a table at a slant.I don't like doing it on the floor.---Jack
Re: Another Source for Travishers
William Duffield
Claire Minihan makes excellent travishers.
http://cminihanwoodworks.blogspot.com/p/travishers_26.html
Last Continuous Arm Settee build
Now that the settee is on legs I can work on the top. I tapered the arm post holes and fit the posts. I drill a hole in the arm for the top of each post. Now I use my handheld reamer and ream the bottom of the hole to fit the arm to the post. Being aware of position as I fit each side. Once I get the arm to sit in the position it will end in,the fit is done.
Before this step I cleaned up the arm with a spokeshave and scraper and carved a couple beads on the front face of the arm.
Now I lay out the hole positions for the spindles to go through the arm. I ended up with two center spindles so I drilled these two holes in the arm and fit and installed both spindles to hold the arm in position for drilling the rest of the holes. Once these are all drilled I measured from the arm to the seat and finished all the rest of the spindles to fit,marking each to it's numbered hole.
Setting each spindle in it's place on the bow.
This next is the final dry fit before glue-up.
The chair all glued together and partially wedged.
After the glue dries I use a drawknife to cut off the parts that stick out above the arm. All pieces get wedged ,the arm posts get wedged top and bottom.
I need to clean everything up and get it ready for paint. This is it for this thread. Thanks for looking. I hope someone will get something useful out of this. Feel free to comment or ask questions.
When I start to paint I will start a new thread and document the painting process. It is a unique process I learned from Curtis Buchanan's videos.---Jack
Terrific job, Jack!!
Bruce, a MN Galoot
It will be good to see the final product, but I've enjoyed the ride.
BTW, how long did it take to get to this point?
Re: Terrific job, Jack!!
I'm not sure. I spent alot of time waiting for stuff to dry. Maybe 30 hours of actual working time. Could be more.It would be hard to measure. I usually have several chairs going at once.---Jack
Re: Last Continuous Arm Settee build
Many thanks for this build, Jack. It has been most informative. I do hope that Ellis will archive these posts in the Articles for future reference.
Re: Thanks and a question.
Hank Knight
Jack,
Thank you for posting your build. I have enjoyed it tremendously. One question, probably a stupid one. How do you wedge he spindles? I'm not a chair builder, but I hought you had to cut slots in the spindles to accommodate the wedges. How do you do that after you've fitted the spindles into their respective holes and cut off the excess with a draw knife?
Hank
There are no stupid questions. We are all learning something.Besides I wasn't very clear about the details.
When I finish gluing up the arm assembly I saw off the excess spindle sticking out of the top. I leave 1/4" or so. Then I split the spindle top with a chisel and insert a wedge. After the glue to the wedge has dried a bit I cut the top flush with the drawknife.---Jack
Hank Knight
Thanks, Jack. That makes perfect sense.
Thanks for the ride!!!!
Ron in Sterling, CT
Jack,
What a beautiful piece, and the journey was incredible. Thanks for sharing the build with us.
Ron
