continuing drawer construction
Brian, mend your ways...but more on that later........
First a disclaimer for the benefit of the onlookers. My drawers are made to a functional standard of significantly less refinement than you all. They are no more than an soundly constructed place to store socks. that said...
Slips were invented to provide a broader bearing surface for the unusual habit of using skinny white oak sides on classic English furniture. Otherwise these abrasive sides would saw their way into the soft mahogany dividers and the wounds would show. In modern times this functional feature has found other application.
I use slips, often when not needed, because they lead to quicker drawer construction. I make slip stock "by the mile" and I have stock at hand whenever making drawers. The alignment block shown in the picture is stored with my drawer making stuff to be available when the slips are glued on. It becomes a trivial task to wind up with grooves aligned to where the bottom slides in smoothly.
I do agree that for some application a flat bottom drawer would be best and I suspect that the desk is one of these applications, as well as the Derek piece. For my sock drawer, not an important consideration.
Given the over the top details of the rest of the desk, the effort of making a flat bottom would not be excessive. But, for that matter, slips on these small drawers are not necessary in the first place.
I have learned to be wary about making creative departures from classic furniture engineering. Cabinet makers optimized construction to be most easily executed and long lasting. Modern tools, materials and techniques can make departures free of risk if they only impact how the piece is made. Occasionally they can have unexpected impact on long lasting. The bottom line is to study how furniture is made and learn from it, as described by Steve Latta in the recent Fine WW article. (disclaimer-Steve is my woodworking hero )
A side note, people tend to make drawer bottoms ridiculously thick which leads to excessively heavy drawers. If someone stands in a drawer, not an anticipation I would devote any engineering effort to mitigate, the bottom should fail, not the sides or front. Even a 1/4" bottom captured on three sides and screwed on the 4th is robust in a medium sized drawer. Bottoms are trivial to fix.
