My saw handle
Joe in a Cleveland suburb
Thanks David, William, and John (and all) for the advice you've given, the beech scraps, emails, wood education, and so on. I really appreciate the help and time you've given to me.
I was able to spend some time on this the last few days and here is where it stands now. It's repaired and will be usable. It's not prefect, but it's the first time I've done something like this. At least I won't get splinters now.
I did the top horn first. I cut out a notch then shaped a piece of beech to fit. The fit was pretty good, but not perfect. I did it this way because I was able to remove (or cut out) the least amount of the original wood. I thought that way if the glue up fails someday, there will still be plenty of original horn left to cut along the grain better and have a better edge grain glue up. I didn't get the grain direction exactly right on the new piece. After I had glued it on, shaped it with a rasp and file, sanded it, I could see it was off...
The bottom horn was cut right along the grain and worked out really well.
So the bottom horn looks a lot nicer. I suppose since I left a lot of 'meat' on the top horn I could redo the top horn, but I'll leave it as is for now.
I put some BLO on it. I'll let that cure a few days, then add some shellac.
Now I need to sharpen it...
Thanks!
Before:
After:
