New WoodChat!
A little morning exercise
Jack Guzman from Maine
I'm starting on a continuous arm settee. I flattened the seat blank this morning. Both sides. It is a 40"x18"x2" slab of white pine. The slab was a little cupped. I use a stanley no.5 with a cambered iron to work it flat and then level it out with a no.7. I was surprised at the size of my pile of shavings when I finished. That board was a good workout. ---Jack
Re: A little morning exercise
That's a purty piece of pine wood!
Barney Markunas
A foolish question... if this is going to be something Windsorish, where you have to dish the seat any way; couldn't you have just gone concave up and let the cup give you a head start on your carving or is that just asking for trouble down the road? I'm guessing that only having to flatten the convex side would have saved you a fair bit of time.
On the contrary,that is a very good question. The reason the seat blank must be perfectly flat has to do with angles. The legs, spindles and arm posts all enter the seat at specific angles. The angles must have a reference surface to measure off of. That surface is the seat blank. When setting up a chair after flattening the seat,I draw the outline of the seat on the surface and mark where all the components are located. Then I drill the holes for all these components at their proper angles into the seat. I don't start carving out the seat until all this is done. It is like doing the joinery in a table leg before tapering or carving the leg. Reference.---Jack
roger lance
do you let it sit awhile in case it moves and then reflatten ??
No I don't go that far. If I flattened a board and didn't use it until awhile later I would check it to make sure it didn't cup alittle but the pine I use has has several years in my shop to acclimate so I don't expect it to move much anymore.---Jack
